Question about Zanussi TD4100W Electric Dryer
DRCS68W Tumble Dryr, not filling condensor tank after fix. I recently took my unit to bits to get out something stuck. When i put it back together, it drys ok but the condensor tank no longer gets filled up with excess water. I'd like some help and also confirmation of if i got the pipes the right way round when i put it back together. Should the grey pipe be on the left or right?? Hope you can help
  • Zanussi Master
  • 12,061 Answers
You should be able to take off the inspection panel, inside should be your maintenance manual. This will help you troubleshoot your issue. and show you where everything goes. If thats no help then you are going to have to get a service manual, or professional help. This website below is dedicated to DIY troubleshooting and repair. http://www.acmehowto.com/howto/appliance/dryer/electric-dryer-repair.php
Posted on Jun 06, 2010
I am trying to replace a belt on a Beko Condenser tumble dryer DRCS68W. I cannot find any instructions or videos online , surely this is something i can do without having to pay someone else to do it.
not same model number .but on my beko....i had to remove side panel.........remove element cover remove motor fan inside fan opening is 4 small bolts,. remove them..... ,.they hold motor to back plate...on front of machine.remove front fan.....then from side panel..remove plastic motor covering and wire harnes...then the motor just pulls forwards remove back plate...and machine bearing...put new belt on.... manover motor back inti place then refit as you took apart..........
chers
Nov 30, 2016 | Dryers
Beko DRCS68W not entering reset mode
If there is voltage on the thermostat but not going through even when the temperature is down it is possible that this could be defective. Now check using a multimeter to confirm the continuity on the thermostat and if the reset switch on this - if present - is off, if so press it down.
Now confirm the voltage from the control panel during the heating cycle and if voltage is outputted then it must flow. The connection must be checked on the heating element- trace to confirm.
Jun 27, 2012 | Beko Washing Machines
My hotpoint aquarius fdw60 wont fill up and is stuck on eco
Read above post - seemed too easy a fix but took my VAX and sucked all the water out if the DW that I could see, then tipped it onto its RHS as above and a little bit more waterspilled onto the floor. The bottom spray arm was also loose - tightened it, Checked for leaks elsewhere - could not see any. Put the DW back together and it is working okay again. Will have clean dished for tea time!
TYVM for the post.
Apr 21, 2012 | Hotpoint Dishwashers
Damper-bottom of hot water heater broke when changed themocouple
U cannot put it back together it is a fail safe if the unit over heats from a plugged inlet the spring loaded damper is released by one of two way solder retainer melts or vial melts either way the the unit is bad contact Rheem with the 1800 number on the tank and depending on the age they will replace the tank. You will have to uninstall it take it back then install the new tank all not covered by them or if you can't do this a local plumber or hvac company can do it for u
Apr 02, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Leaks water in the counter.
I fixed mine for 25p... you need to take the back off, and the tank holder out (2 screws each). There is a very thin pipe that comes out the pump - that is the leak.
Unclip the little clip and pull out the pipe and fish out the black o-ring out the hole.
Buy a new o-ring and put back together... no leaks =)
May 24, 2009 | Krups XP4030 Espresso Machine
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
TUMBLE DRYER
Hi, It wont fill up when the full tank light is on because it thinks the tank is full. Remove the tank and feel down inside where the tank sits into the machine. You should feel the switch, it sounds like it is stuck down.
Jan 03, 2008 | Tricity Bendix AW1400W Front Load Washer
Double vision
it looks like when you took this apart you did not alignt the lenses properly, there should be a locating groove or stub which these lenses should fit to... it looks like they are pressing against the stub but are not located properly, hence the distortion. try taking it apart again....when you put it back together again the fault may have gone.
Sep 29, 2006 | Wesco WS7 Microscope
Zanussi TD4100W Electric Dryer Logo
229 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
