Question about Canon imageRUNNER C3200 Copier
In printing colors are 1 mm apart from each other
  • Canon Master
  • 12,061 Answers
Www.blueridgecopier.com/...Manuals/.../Color%20imageRUNNER%20C3200%20Reference%20Guide.pdf
Above is your user manual, below is a pay for service manual, a sort of must have to get any chance of a repair, really. http://www.tradebit.com/tagworld.php/copier+service+manual
Below is a free generic, service manual for your series of printer, this will help address your issue. http://printer1.blogspot.com/2009/01/canon-ir-2200-service-manual.html
Posted on Jun 06, 2010
My Canon Pixma ip3300 prints on top of an absolutely perfect printing, a sequence of stripes colored in magenta, the stripes are 2,7 mm wide and are 2,7 mm apart from each other. All other functions of...
try to clean the ink print head cartridges also its trailing (belt, pulleys) you can reach. a dirty ead may cause that or better check it to printer solution software, there you can test, align, clean printhead.
Feb 12, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
Problem with the Canon imageRUNNER C3200 Copier In printing colors are 1 mm apart from each to other
You need to clean the rollers in the "Internal transfer belt". I'd suggest you contact Canon service, because you could easily break the thin Transfer belt if you do it wrong. Temporary solution is to turn the machine off and then on, following a FULL color calibration.
Feb 03, 2011 | Canon imageRUNNER C3200 Copier
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
I have had a HP laserjet CP1215 for few months and it has printed OK. Now, just in the middle of printing one color, magenta misaligned from other colors. It prints about 1 mm above all other colors...
My first thoughts were to refer you to the on-line information on Color print quality issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01691296&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3422476
Work through the steps that are outlined with special emphasis on Solution One, Eight, Ten and Eleven.
My next thought would be to download, install and run the HP Print Diagnostic Utility:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02582853&lc=en&dlc=en&cc=us&product=3422476
But I am betting you have already done all this. Grasping a little and hoping this is not a mechanical issue you might try, Performing Cold Reset (Factory Defaults):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01530973&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3422476
If none of this works you may need a technician to make a mechanical adjustment to the nozzle head If it was a recent purchase and under warranty I would consider returning it.
Dec 10, 2010 | HP LaserJet CP1215 Color Printer
Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
Out of paper
Cause: There is not enough paper in the input tray.
Solution: If the HP All-in-One is out of paper or there are only a few sheets
remaining, load more paper in the input tray. If there is paper in the input tray, remove
the paper, tap the stack of paper against a flat surface, and reload the paper into the
input tray. To continue your print job, press OK on the control panel of the HP All-in-
One.
Cause: The rear door is off the HP All-in-One.
Solution: If you removed the rear door to clear a paper jam, replace it.
rear door.
Paper can also jam in the automatic document feeder. Several common actions can
cause paper to jam the automatic document feeder:
• Placing too much paper in the document feeder tray. For information on the maximum
number of sheets allowed in the automatic document feeder, see Technical
information.
• Using paper that is too thick or too thin for the HP All-in-One.
• Trying to add paper to the document feeder tray while the HP All-in-One is feeding
pages.
To clear a paper jam from the rear door
1. Press in the tab on the left side of the rear door to release the door. Remove the door
by pulling it away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Paper specifications
This section contains information about paper tray capacities, paper sizes, and print margin
specifications.
• Paper tray capacities
• Paper sizes
• Print margin specifications
Type Paper weight Input tray1 Output tray2 Document
feeder tray
Plain paper 16 to 24 lb. (60 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 35
Legal paper 20 to 24 lb. (75 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 20
Cards up to 110 lb.
index (200 gsm)
40 10 N/A
Envelopes 20 to 24 lb. (75 to
90 gsm)
15 10 N/A
Transparency film N/A 25 25 or fewer N/A
Labels N/A 20 20 N/A
4 x 6 inch photo
paper
up to 145 lb. (236
gsm)
30 10 N/A
8.5 x 11 inch photo
paper
N/A 40 20 N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
HP recommends emptying the output tray frequently.
Paper sizes
Type Size
Paper Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Chapter 15
266 Technical information
Type Size
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium photo paper 102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
inches)
Top (leading edge) Bottom (trailing
edge)
Left and Right
margins
U.S. Letter
U.S. Legal
A4
Photo media
1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
Envelopes 16.5 mm (0.65
inches)
16.5 mm (0.66
inches)
3.3 mm (0.13 inches)
Print specifications
• Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
• Method: drop-on-demand thermal inkjet
• Language: Lightweight Imaging Device Interface Language (LIDIL)
• Print speed varies according to the complexity of the document
(continued)
Print specifications 267
Copy specifications
• Digital image processing
• Up to 100 copies from original (varies by model)
• Digital zoom: from 25 to 400% (varies by model)
• Fit to page, pre-scan
• Copy speeds vary according to the complexity of the document
Mode Type Scan resolution
(dpi)1
Best Black up to 600 x 1200
Color up to 600 x 1200
Normal Black up to 300 x 300
Color up to 300 x 300
Fast Black up to 300 x 300
Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
http://get.adobe.com/reader/
Also, once you have done all you can turn the printer off for a moment then turn it back on.
Hope this helps. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
Repeating defects problem after all consumables
Hi thpep:
Here is a repeating defects ruler. Mach the first defect at the top of the page and alighn with this ruler and it will tell you what assembly is giving you the problem.
Repeating Defects
Routine
Maintenance Item Component Distance between Defects
Imaging Unit Developer Roller [YMCK] 28 mm (1.10 in.)
Drum [YMCK] 62 mm (2.44 in.)
Drum Charge Rollers 25 mm (1 in.)
IDT 1 (Y and M, C and K) 132 mm (5.20 in.)
IDT 2 all colors together 132 mm (5.20 in.)
Transfer Roller Transfer Roller 64 mm (2.52 in.)
Fuser Assembly Fuser Assembly 82 mm (3.23 in.)
Defects Associated with Specific Printer Components
Some print-quality problems can be associated with specific assemblies, the most
common problems and the associated assemblies are listed below. Also, refer to the
specific print-quality troubleshooting procedure for more information.
Imaging Unit
■ Streaks
■ Fine Lines
■ Banding in Process Direction
■ Uneven Density
■ Voids
■ Repeating Defects
Transfer Roller
■ Toner on the back side of the printed page (simplex mode)
■ Light Prints
■ Repeating Defects
Fuser
■ Hot or Cold Offsetting
■ Repeating Defects
Hope this helps
pdouglasss@hotmail.com
Jul 16, 2009 | Xerox Office Equipment & Supplies
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
Hp 2600n color printing problem
are you using orgnial hp cartridge if not check that it may cause due to that. check the black sheet fro color spreading , if there is any color pls clean that.........
Thank you
Feb 19, 2008 | HP Color LaserJet 2600n Printer
Canon imageRUNNER C3200 Copier Logo
178 people viewed this question
old marine
old marine
