Question about HP LaserJet 1600 Printer
Prints double image -- everything printed has a double image. Looks like a ghosted image and is offset to the actaul page.
  • HP Master
  • 12,061 Answers
Http://www.fixyourownprinter.com/forums/laser/42756
Hi this link above directly addresses your issue with a view to a fix.
Below is how to troubleshoot your issue, it seems it can be a few things.
Below is your service and repair manual, that will have what to do. www.partshere.com/.../CLJ1600%20removal_replacement.pdf - United States http://www.streetdirectory.com/travel_guide/118490/printers/solving_image_problems_on_hp_laser_printers.html
Posted on Jun 06, 2010
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
Towards right hand side of printout, characters ap...
If you are getting a "shadow" behind the text or image it is probably your fuser that is causing the problem. Anytime you see a double image or the print is smearing the fuser (aka fixing assembly) is to blame. You can troubleshoot the problem to see for sure before calling out a technician. Send a one page test print job to the printer. Open the rear "output" tray so that the print job exits the rear of the printer. Watch the paper as it is pulled into the machine. When you see the leading edge of the print exiting the printer open up the front door of the printer. This will of course cause the machine to jam up but its worth it. Carefully remove the toner cartridge. Look at the print on the page still inside the machine. Do you see the same grey image? If not then the problem is the fuser. If you do see the grey image then the problem is the toner cartridge. Stopping the print job in the middle of the printer like that allows you to see what the image looks like before it goes into the fuser. If the fuser is the problem call a tech. It is about a $100 - 150 repair for the fuser depending on the labor rates where you live.
May 20, 2010 | HP LaserJet 1150 Printer
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
May 14, 2010 | Brother MFC-7820N Laser Printer
Double printing or 'ghost' images
you need to change your toner opc drums
Dec 13, 2009 | HP LaserJet 1020 Printer
My 2300W prints a second image
Yes, it sounds like a fuser problem, as the oil and coating wear off of the fuser rollers they transfer to the page as you describe. The only way to tell is to stop the machine in a print cycle before the fuser to determine if the problem is before or after the fuser.
Aug 31, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Double printing in my samsung 3160 fn
Double printing, such as second "ghost" image has nothing to do with cleaning, but with the drum unit. Print out the System Data Report (Press [MENU] until "System Configuration", then right arrow until "Reports", press [ENTER] and then right arrow until "System Data". Press [ENTER] twice to confirm.
With the report on hand, check the total color prints. If they are near 12,000 pages, change the drum. Be advised, the Image Unit (drum) is an expensive consumable. Part number is CLP-300A.
Be blessed.
Oct 01, 2008 | Samsung CLX 3160fn All-In-One Printer
AKAI PT5598HD ghost image the red is offset
Replace STK392-040 IC's with name brand only. No generics.
I use Panasonic brand with no recalls.....Let me know if you
need more help.......................T.
Please rate this solution...........thanks.
Nov 11, 2007 | Akai PT5598HD 55" Rear Projection...
HP LaserJet 1600 Printer Logo
482 people viewed this question
Seeker5211
Seeker5211
