Question about Weaver NightView (849397) Monocular
How to fix the Weaver NightView #849397 power button short.
I'm a fix it kind of guy and a friend of mine has two of the Weaver NightView #849397 Monocular that don't work. Right away I can tell that the power button is melted. I bypassed the main on/off power switch and it did not turn on and it drained the batterys. So my question is, do you know how to stop or fix the short and make it work normally?
My Bushnell Banner rifle scope 3x9x40 ia at max elevation and shoots low The scope is used on a marlin 1894c underlever rifle and attached to a weaver rail how can i fix this problem
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
Feb 27, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Unit does not turn,I think it needs a switch,looking for some place local for repair.Returned to weaver twice problem still exists
Jemenie!!! Apparently Weaver doesn't know what to do. Call the big boss and give a ear full.
It could be a bad switch, broken wire, bad image tube, faulty ccfl inverter, multiplier. Without some troubling shooting it, it is impossible to tell. stewbison
Feb 26, 2011 | Weaver NightView (849397) Monocular
Hot batteries melted battery carriage and power supply wire
It can't be repaired It probably got the ccfl inverter also. Sorry. What are you going to do with it.
GB,,,stewbison
Jan 17, 2011 | Weaver NightView (849397) Monocular
I have a Meade nightview night vision monocular. When powered up i only see a gray screen with no images at all. ir function works fine. Meade tells me that they no longer service these models. Please help
Hello, sorry, it is a bad image intensifier tube. 90% of the troubles with these Russian manufactured tubes they are not manufactured very well. Poor quality control on many of their consumer goods...junk. GB,,,stewbison
Jan 14, 2011 | Meade NIghtView NIght Vision Monocular
Humming noise when turned on. no picture. is there a reset button
There is no reset for this kind of problem. The chances are that the flyback transformet is shorting, horizontal output transistor is bad, or possibly bad power supply board. The unit will have to be opened up and troubleshot. Some RCA units seem to be prone to this problem, and a friend of mine paid $300 twice within 6 months, so I can't vouch for RCA's long term reliability.
Hope this helps.
Oct 26, 2010 | RCA F35673MB 35" TV
What kind of base would you use on a TC pro hunter
You base must be compatible with the type of mounts you use. You will have to get a gunsmith to fix them so if you decide to use weaver mounts for example, the logically you would use a weaver rail. Be cause different mounts have different holding methods, first select the scope you are going to use. Once decided then find a set of mounts that you are happy with and from there you select a rail that will accommodate your mounts.If in any doubt, ask the person who is doing the work for you for advise.
Feb 13, 2010 | Weaver Optics
Hey guys would you be so kind to try to help me out? a friend brought me a pc with an abit IS7 motherboard it can't boot instead, all fans start working then a red light, 3 short peeps and it stops. What...
The beeps might indicate the problem with RAM. Try plugging out the RAM modules and insert them back in one by one in different slots and then check.
Jul 17, 2009 | Abit IS7 Motherboard
Printer wont switch on
hi im josh in cebu phils. may i help you friend? Friend such problem occurs when there is a shorted parts inside.it doesn't turn on for now because built I.C. of printer and pc has an auto shut off lever that automatically shuts of every-time time the board has an unusual problem especial short circuit. Friend  1.try to check the connections of the power chord be sure it is not shorted. 2.Check the power switch button of the printer maybe there's something stuck on it that makes the connection shorted or faulty. Good lcuk friend hope i helped you.
Mar 14, 2009 | Canon PIXMA MP760 All-In-One InkJet...
The menu is always pop up
so what is the best solution guys?
Oct 30, 2008 | AOC CT720G 17" CRT Monitor
Weaver NightView (849397) Monocular Logo
91 people viewed this question
Top Weaver Optics Experts
colinat108
james laughton
james laughton
Are you a Weaver Optic Expert? Answer questions, earn points and help others
