Question about HP VP6121 Multimedia Projector
Hp VP121 needs new bulb?
I went to power up my projector tonight. When I turned it on it made the typical sounds but the light didn't go on. No picture on the screen. The power button flashed and the bulb icon light lit up. I haven't had any warning that my bulb may be used up. I'm not sure of the hours nor can I power it up to check. I'd like to be sure it's the bulb before I drop 300 on a new one. Any suggestions? Thank you.
  • nsd0222 May 05, 2009
    I have the same problem, except that when i turn mine on, it will come on for a few seconds, and then shut down and turn the bulb light on. I bought a new bulb because I assumed this was the problem, and this bulb worked fine (with poorer than usual pic quality) for about 2 1/2 weeks, then the screen flickered, the fan got real loud, and the projector died again. Does that mean anything to you Marrie?
    Problem Solver:
  • 5 Answers
I'm not convinced the bulb is blown.
I have a working VP6121, but the bulb seems a bit dim. I read of some fault on a similar projector going into standby and not turning the bulb on, so I tried a little experiment.
I removed the bulb, and turned the projector on.
Nothing - except for a very feint slow clicking coming from within.
The projector did not turn on, nor did it go into standby.
The bulb assembly only contains 2 contacts, with NO interlock.
So, it would seem that turning the projector on from cold, with no bulb or with a blown bulb, the VP6121 does nothing.
Hope that helps.
Posted on Jun 14, 2009
  • grahamjat Jun 16, 2009
    Whilst doing some browsing, I discovered that the HP VP6121 series of projectors are remarkably similar to the BenQ PB8120 and PB8220 projectors - in fact, almost identical.
    On this Fixya web-site, you may find a solution to the powering-up problem by going here http://www.fixya.com/support/p190458-ben...
    In summary, it seems the power-off sequence has a lot to do with the problem.
    Hope this helps.
  • 563 Answers
Hi there
Take out the lamp and check for any marks on the inside ( shaft ) of the lamp. If there is marks or discolouration on it then you can be 100% sure it is the lamp.
Posted on Apr 10, 2008
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I pickd up my prjector while it was on. i turned it over an i head a POP and all the lights went on so i pulled the plug now it wont turn on... what is the prob?
The POP sounds typically means the project bulb blew (just like a typical light bulb). You can take it into a repair shop to have the bulb replaced.
Feb 25, 2011 | Dell 2300MP Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Jan 26, 2010 | Hitachi ED-S3170 Multimedia Projector
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
No display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Aug 10, 2009 | HP Digital Projector Vp6110 Multimedia...
4805 w/less than 300-400 hours has blinking red light
Yikes. I bet the bearing is bad in the fan and/or the fan is rubbing up against something. It might be an fix.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
How to replace an hp 070 projector lamp
undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
Dec 04, 2007 | Office Equipment & Supplies
HP VP6121 Multimedia Projector Logo
512 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
