Question about Indesit Dishwashers
Our indesit dishwasher is not working and showind an A08 code on its display panel model no: DE73UK
  • TOM PARKES Jun 06, 2010
    where abouts is the thermistor or the heater situated in the dishwasher model DE73UK
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error A08 means Open/Short circuit auxiliary wash motor triac which refers to a heating failure. You’ll have to check the thermistor as if that is bad should be replaced, also check the heater and replace if it has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
Indesit dish washer is showing error code A08 why
from what i can find out, it means (auxillary wash pump triac cloesd/open circuit)
Sep 25, 2011 | Indesit 24 in. DE73 Evolution...
Our indesit dishwasher is not working and showing a A08 code on panel model DE73UK
A08 - Open/Short circuit auxiliary wash motor triac -
This is the power transistor that carries motor current. It is signaling that it is blown, but this usually happens when the circulation motor is faulty. Both need checking, and likely replacing.
You may be stuck with a bill for a new motor AND a new control board.
Jun 06, 2010 | Dishwashers
Indesit dishwasher DE73 error code A08
Hope this helps
Apr 06, 2009 | Ariston Technologies Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
A05 code
ao5 is showing on the display of my indiset de73 dishwasher
Aug 19, 2008 | Indesit 24 in. DE73 Evolution...
Dishwasher
A08 is a problem of the mother board , i changed this and i paid 130.000 for a **** ten minutes of work but i didn't resolve the problem. i waiting for another mother board.
Aug 13, 2008 | Indesit 24 in. DE73 Evolution...
Indesit DE43UK dishwasher. Water only gets lukewarm, intermittently gives Fault code A03 - "thermistor short circuit". Indesit says no such part as thermistor listed for this model. Indesit will...
INCREASE THE WATER TEMP AT THE HOUSE WATER HEATER SO YOU WILL HAVE 120 DEGREE WATER COMING INTO THE DISHWASHER. IF THE DISHWASHER IS NEXT TO THE SINK, PURGE THE HOT WATER LINE AT THE SINK UNTIL YOU ACTUALLY GET HOT WATER. THEN, START YOUR DISHWASHER.
Apr 03, 2008 | Dishwashers
Indesit DE73 showing A08 fault code
Sounds like it has overflowed at some stage. Ensure the filter is cleared and then rock the dishwasher backwards. Any trapped water will drain out and the safety valve will reset. i had similar and this was what the indesit technician did.
May 21, 2007 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
110 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
