Question about IBM ThinkPad T20 2647 Notebook
Ibm t20 no LCD backlight
Last night i worked with my t20 without any problem. morning when i switched on my laptop i saw the windows with dark background without having backlight. plz help me
zakeerhussain
zakeerhussains@rediffmail.com
  • 77 Answers
While the T20 is on and manifesting the dim display....
1. try to slowly close the lid (but not totally closing it) and then pulling it back to its original position slowly. Tell me if the light goes back.
if by doing that action the backlight lights up, you are most likely faced with a Flex cable problem. You might need to buy this from ebay. (dim display problem in T20 series is very common these days due to wear and tear of the flex cable)
2. Also try to use a pen to turn on and off the limit switch that triggers the backlight. This is located above the keyboard below the lcd. See what happens.
Posted on Apr 10, 2008
IBM T20-How can I find out if the screen or the backlight
connect an external monitor and check...if display siganl is being sent to the monitor...
to check if ur inverter board or backlite is out u need to open the screen and check that out...
Dec 18, 2009 | IBM ThinkPad T20 2647 Notebook
My view sonic monitor gat very dark. can still see but very dark. do I need a new monitor ? was fine last night and this morning had problem. I didn't shut down over night.
It sounds as though either the backlights or the inverter(which supplies power to the backlights) has gone. If you can still see the desktop but only if you look closely and it is very dark, then the monitor will need repairing or replacing. If it is the invertor it can be done at a resonable cost - if it is the backlight it would probably not be worth repairing. Also it will cost just for an engineer to check it out.
Nov 16, 2009 | Computers & Internet
IBM R50
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 22, 2009 | IBM ThinkPad T23 Notebook
Ibm laptop 2647 series23 the power is on no monitor screen lite
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 04, 2009 | IBM ThinkPad T20 2647 Notebook
Screen is very dim..can barely see it..bright adjust doesnt help.
Hi, your LCD screen's backlight has gone out. This is a hardware failure, and you'll need to have it replaced or repaired. THe LCD screen consists of two parts, the LCD screen which creates images for you to see, and the backlight which forces light through the LCD so you can see it. Your backlight has gone out, so your screen still has images, but no light.
May 17, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm r50e laptop no black light
dear sir
if u have a booting problem then when u start yr laptop press F11 key and go thru instraction stape-by-stape then recover yr regisery to before near date then it's help u
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | IBM ThinkPad R50e Notebook
Black Screen
mostly like is your lcd screen...you can try to see if your laptop still working by connect to external monitor.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
Backlight not working?
No easy fix i'm afriad, the backlight needs replacing...there are plenty of guides on the internet that show you how to do it, but its a sensitive job as you run the risk of damaging the LCD screen itself, the backlights are available on eBay.
My advice is to way up the cost first of a replacement laptop, or a replacement LCD screen with the backlight fitted, or if you feel confident enough about replacing the backlight yourself then just by the backlight and track down the guide for the disassembly.
Hope this helps...!
Cheers
Jun 11, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
361 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
