Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The door only opens partially and then stops
The garage door only opens partially and then stops about a fifth of the way up. I have detatched the emergency rope from the bracket on the belt and manually opened and closed the door.
I re-attached the door to the drive belt again from the fully opened position and it closes perfectly but again only opened partially.
Any suggestions would be awesome. Thanks
  • 504 Answers
IF THE DOOR WORKS WELL MANUALLY.
ADJUST THE UP SENSITIVITY ABOUT 1/8 TURN AND TRY AGAIN.
HOPE THIS HELPS
Posted on Jun 07, 2010
My garage door opener does something different every time.Opens partially. Closes partially. Sometimes you have to push button multiple times for it to do anything. Who knows what it will do next.
this is likely a force setting issue, with all the humidity the door might be getting more stiff, on the back or side of the unit there should be a screw it adjust, or you can reference the manual, but before doing so you should release the door from the opener (handle on the trolley) and check to see just how stiff the door is, if the spring has broken you will have to get a door guy to fix it.
Jun 07, 2017 | liftmaster Chamberlain Garage Door Opener...
How do you stop the door leaving a foot open at the bottom?
To stop the door in a partially open position, the button on the wall switch or remote should be pulsed when the door is opening from the fully closed position.
Jul 12, 2014 | liftmaster Garage Door 1/2 Hp
Why does my python2 garage door open by itself. partially and all the way?
Change your code. Sounds like one of your neighbors are on your current code
May 07, 2014 | Building Materials
Fifth door on lexus rx330 will not close
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: diyobd2.fr
Apr 03, 2013 | Lexus Cars & Trucks
Door closes but opens inmediatelly and partially,only 1 foot and a half
With the garage door up pull the release cord to disingage the garage door it self in the up position. You can skip the disengaging step, But,It saves ware and tear on the motor.
Then using a step stool you will find limit adjusting plastic slots/screws on the side of the opener.
The left screw is for garage door down.
I would turn the left screw clockwise 1/2 turn or less. then activate the remote opener. noting which way the latching mechanism moved. and so on.
It may take a few adjustments with this proceedure to get it perfectly closed. Then activate the remote to re-engage the garage door it self.
Also, LiftMaster has a web site that you can check out.
Jul 23, 2011 | liftmaster Garage Door Limit Switch...
Check to make sure you don't have a broken door spring. Then remove the cover from the motor unit and check the drive gear. It is a white nylon gear and will be obvious if it is bad. If neither of these are the case you can increase the up force. The up force control is on the rear of the motor unit near where all those white wires go.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Random operation of Chamberlain HD900D garage door opener
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.
Dec 05, 2009 | Building Materials
GARAGE DOOR OPENER WORKS INTERMITTENLY
Check to make sure your door sensors are properly aligned. They each have a small light and both lights will be on if they are aligned.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,510 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
