Question about Ovens
Hi my mother has a Blanco 900mm electric wall oven and it is now not heating and the fan at the back is not spinning any help as to what it might be and if it can be fixed would be great, thanks
  • manz80 Jun 06, 2010
    Hi now I am confused should I be looking for a fuse or not, please if someone could clarify, thanks
    Hi would this cause the fan not to work too? thanks
  • 713 Answers
Hi,from your problem,it's obvious that the problem is a faulty fan oven element.
To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit.
Thanks and good luck
Posted on Jun 06, 2010
  • Oyelade Gbenga Jun 06, 2010
    Yes ,this will affect the fan not too work,hope you are technically inclined to do this,
    thanks and Good luck
    Novelist:
  • 238 Answers
It can be fixed, do not worry.
There ara a couple of points to be controlled.
Lets begin to control them.
Please check the followings.
Both electric oven and its fan is not working means that there is a fuse problem.
Electric fuse must be checked firstly.
1. There are two electric fuses. One is in the Oven other one is in the House Electric Panel.
a.
Is there electric in the electric outlet?, or is there any different fuse in the house electric panel? If both of them normal, then go on the following.
b.
If house electric control panel fuse is normal then you should check the fuse in the oven.
If you can not control the fuse in the oven give me some information what did you do and I will continue to help you solve the problem. Please leave comments untill the problem is solved.
  • 6 more comments
  • FIKRET UNALIR
    FIKRET UNALIR Jun 06, 2010
    Please write exactly the brand and the model name.
  • FIKRET UNALIR
    Meanwhile the below link can help you.
    Please have a look at the link.
    http://www.fixya.com/support/r4511800-ov...
    Hi thank you for your help, the model number is bms901sse, it is a Blanco 900mm oven in stainless steel, where exactly would the fuse for the oven would be? thanks for your help.
    sorry I meant where in the oven would the fuse be because the one forthe house is fine, thanks again
  • FIKRET UNALIR
    I am trying to solve. Please do not worry.
  • FIKRET UNALIR
    I could not find the exact place of the fuse. But you know, it should be inside the oven. And there is at least one fuse in it. Try to find it. In the front cover, there is a panel on the right hand side and there is another one at the right hand side. Try to unscrew and remove one of them. BE CAREFUL before doing this, you should remove the main power.
    Then it is very easy to open the panels. After opening look carefully to find the fuse. If you find and correct it the problem will be easily solved.
  • FIKRET UNALIR
    I wondered what happened to Oven.
    Did you find the fuse in it.
    I have found your manual of your Oven. Please look at the following link
    http://www.4shared.com/document/Tbqaoak_...
    I hope it helps.
  • FIKRET UNALIR
    It is understood that the fuse in your oven is well. Do not try to find. The problem is the resistance of your oven. This can not be done by yourself. Please contact with your nearest authorized service center. If you had given this information I could doubtedly say the solution.
I have a GE Profile Wall Oven. JT910SASS. The cooling fan makes a loud noise. How do I replace it? Where is it?
Firstly, you don't need to replace your fan simply because it's noisy. It may be sufficient just to grease the spindle/bearings.
The fan is located at the back of the oven and CANNOT be accessed from inside the oven. If you open the oven door, you will see a grille at the back of the oven compartment - basically just some slots and holes cut into the back panel. Behind this grille is the heating coil/element, then another panel, behind which is the fan/fan motor. Basically, the fan is right at the back, dead-centre of the unit.
To access the fan, you will need to remove the oven from the wall cabinet and remove the back panel. To do this, you first need to unplug the oven or, if it's hardwired, detach the cable from the outlet - power off please! Next, remove the retaining screws at the on both sides of the oven at the front - these are only revealed when the door is open. You should now be able to remove the oven from the wall cabinet by pulling it forwards gradually and feeding the power cable through as you do it. I suggest getting someone to help you lift it out as they are fairly heavy and awkward to hold/carry. Also wear some old clothes as the bottom of the unit can be quite greasy!
Put the oven somewhere safe where you can access the back of the oven easily. The fan is covered by a removable back panel. Undo the screws (about 10) around the edges of the panel and partially pull the panel away - taking care not to snag any of the wiring behind the panel. You will also need to remove the connectors to the main power cable to remove the panel fully. Make a note of the connections (or take a photo) to ensure you reconnect it correctly!
You should now have clear access to the fan. Inpsect it visually to see if the blades are broken and try spinning it by hand to identify where the noise is coming from. If the blades are sound apply some HMP grease around the spindle which rotates the fan. This can be quite tricky, so it might be easier to liberally apply some spray lube around the area. Spin the fan by hand a little to work the lube in.
Next, test the oven before putting it back into the wall cabinet. This can be done by replacing the back panel and plugging the oven into a socket or extension cable. If the oven was hardwired, attach a plug to the end of the cable. Turn the oven on at the minimum temperature and let it run for 5-10 minutes to allow the lubricant to work through. If the noise has diminished or gone, reinstall the oven in reverse order of the above. After refitting, I suggest running the oven empty on a low-mid temperature until the smell of lubricant has gone.
If the fan is damaged - or you can't get rid of the noise by lubricating it - then you will need to buy a new motor and fan blade. Fitting these is easy with the back panel removed as they simply bolt/screw onto the back panel of the oven and the wires just slide on and off. If possible, take some photos before removing the old fan/motor to ensure correct fitting of the new parts.
Please post back if you need further assistance.
Hope this helps.
BElectric
Nov 02, 2010 | GE Profile JT910SASS Electric Single Oven
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
How do I remove the hinges from a Blanco BOS402
slide the oven out from the wall. You should be able to remove the hinge from the side.
Sep 13, 2009 | Ovens
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
I have a southbend silverstar.
check your fan to see if it is clogged or dirty
Oct 10, 2007 | Equipex PZ-330 Electric Single Oven
Noisy Oven when heating up & fan spinning
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
Sep 12, 2006 | Baumatic B180 Electric Single Oven
Ovens Logo
260 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
