Question about Hawking HFS24T 24x10/100 Mbps and 2x1000 Mbps Networking Switch
Hawking hfs24t switch bad internal opern frame power supply
Bad power supply
looking for replacment
sea sonic electronics ltd
pn PC1FSF01A6 REV A6 2001/11/27
MD: SSF-025X-XX.
PSSA665205909
It's a litter swithcher That looked really easy to fix until I turned it over and saw extra small SMD's.
After replacing fuel pump in tank the rev. counter can't reach 3000 rpm and engine has no power in Jeep Liberty ltd 3.7 2006
remove the pump again check for anything restricting the pumps inlet and make sure when the pump is put bacl that none of the pipes has a twist or bend that will restrict the flow of fuel
Jan 26, 2016 | Jeep Cars & Trucks
Wy dose the tv always make noise like some is poping inside it
popping inside electronics usually means it's power supply internally may be going bad.
Some units have "switching power supplies" and you might hear a very light click when it switches. Loud pops or frequent louder clicks are a bad sign.
Nov 29, 2015 | TCL L40FHDM12 40 Class LCD HDTV - 1080p,...
My board is IBM rev. 2.8 pn 19r2563,i just clear the cmos,after that the board didn't boot anymore,no power at all,,please somebody help what exactly the problem is..
Look on the board for bloated or leaking capacitors- these are caps that have an x on the top and a yellow or brown substance out of them. If the are fat they are bloated. Next, I have had this with bad power supplies. Try another power supply or put that one on a power supply tester if you have one. It will tell you if all the voltages are there. It only takes one voltage missing to give you major headaches. If the unit is old try measuring the CMOS battery. A dead one will not let the computer boot but that is after power will come on.
If you have a bad capacitor on the board it will be needing replacement- I fix them but not everybody goes to that trouble.
Sep 23, 2012 | IBM Computers & Internet
Cost of replacing body electronic control unit
The body ECU usually costs about $700, depending on year and model but it's an average price from the dealer. There are other things that may cause the defroster to not turn on including an open fuse, a bad switch or an opern citcuit in the wiring.
Nov 26, 2011 | Toyota 4Runner Cars & Trucks
No sound but have power
Not sure which model you have as there are at least 13 cobra 29's. I am using the LTD as an example. Do you have a good good mic and cable? Is it made for this model? If it is good then I would have to say the final audio stage is not working. The TA72222AP is the IC that is the final audio amplifier. Check pin 1 of the TA72222AP ic for 12 volts. If 12 volts is present then replace the audio IC TA72222AP. If 12 volts is not present then you have power supply problems that are internal. Is there meter movement during modulation check? If so then your audio is fine and I would check the spkr jacks and speaker. Plug in another speaker in the speaker jack and see if it works now. If so then of course your speaker is bad. If that all fails then I'm 99.99% sure its the final audio stage is a bad. If your model is not the LTD then the IC could be different but still the same audio final is bad. Replace the part which should be fairly inexpensive. If it uses a metal heat sink be sure to apply heat sink grease when installing new part.
Feb 26, 2011 | Cobra 29 LTD CB Radio
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Wont power up,!help
This 2006 model, and more likely to have bad caps by now, please see picture here to see what goes bad in SAMSUNG and other monitors just as well: http://s807.photobucket.com/home/budm/allalbums
Post back what you find inside.
Apr 02, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Philips Projection 60PP90200D/37 NO PIC NO SND 6X/1QF
I had the same problem. It is error code 61 which is a power supply fault. Had a bad LSB board (pn: 313926719011 from MCM Electronics) which blew out on of my CRT. If you have any observed arcing in your CRT's, they are bad and will need to be replaced. I went to Ebay and found a used compatible Philips brand to replaced the CRT. Do not isolate the high voltage lines of the bad CRT to troubleshoot with a bad LSB. The LSB will short out another CRT (it did on mine). I bought the service manual an learned the set does not tolerant of power line surges. If you fix it, invest is a good surge protector.
Aug 27, 2009 | Philips 60PP9200D Television
I HAVE 2 NETGEAR FS516 SWITCHES. BOTH NEED A NEW POWER SUPPLY.
Replace capacitor C3 47uf@25V. It will fix that ADP20KP 90% of the time.
Mar 05, 2009 | NetGear FS516 Networking Switch
Open Questions:
Hawking HFS24T 24x10/100 Mbps and 2x1000 Mbps Networking Switch Logo
407 people viewed this question
Top Hawking Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Steve
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
