Question about Riccar R1570 Mechanical Sewing Machine
My Riccar 888 sewing machine runs by itself after I've lifted my foot from the pedal. Could the problem be with the pedal or is it something else. What do you recommend?
  • 192 Answers
SOURCE: foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Posted on Apr 08, 2008
  • 8 Answers
SOURCE: beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Posted on Apr 27, 2008
Richie_asg1
  • 1036 Answers
SOURCE: White Sewing Machine 979
I'm sorry I don't know this model, but will try to help you.
Are the buttons still functioning - or is one deffinately seeming broken?
Try selecting other functions and see if there is any life at all.
If there is no life in it whatever, remove the fuse (test it) and replace.
If still nothing, There is an electrical fault either in the foot pedal, or motor.
These can be tested with a meter to determine the fault.
Repair of the motor or footpedal (dependent on tests) may be required - usually the motor.
Hope this helps - if so, rate as fixya!
If not, I'll try and Identify the fault.
Thank you for using Fixya!
Posted on Jun 14, 2008
  • 323 Answers
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
Posted on Dec 29, 2008
Michaelle
  • 65 Answers
SOURCE: machine keeps sewing after foot pedal is off
there is something stuck in the pedal causing the electric circuit to connect, perhaps some thread or a pin.
unplug it from the machine and see if you can unloose it from under the panel.
Posted on Jan 24, 2009
Riccar 555su was given to me, is there an on/off switch? Can I remove a knee controller from cabinet and replace with a foot controller? Thanks.
Most foot controllers are attached to the cabinet to be used as a knee control. If yours appears to be a foot pedal and the cords are long enough, you can probably remove it from the cabinet and try it on the floor.
Riccar Instruction Manuals
Introducing with my Riccar 555SU part
Oct 24, 2016 | Riccar Sewing Machines
My riccar 555su machine starts sewing as soon as I plug in. Foot pedal is stationed inside cabinet by knee, but I'm not controlling it.
The pedal is stuck in the ON position. Unplug the sewing machine and try to open up the pedal to inspect it. Or try pressing the pedal a few time to loosen up the pedal movement. Good luck!.
When stepping on pedal, my juki 5550 straight sewing machine, why will the machine not run? Light works but not machine
there could be something wrong with the foot pedal, it may need to be serviced or replaced, or there could be something wrong with the plug where the foot pedal plugs into
Feb 20, 2015 | Juki DDL-5550 Industrial Straight Stitch...
How to fix foot control
have someone with a multi-meter open the foot pedal and test with the meter. It probably needs replaced.
Sep 17, 2012 | Riccar Sewing Machines
The foot pedal of my riccar 440 went up in smoke the other day! Where can I buy a new one?
Standard type foot control should be able to get one from any sewing machine shop
Sep 03, 2011 | Sewing Machines
Need instruction manual for Riccar 888.
Found the instruction booklet to my machine, and ordered it.
Feb 24, 2010 | Riccar Sewing Machines
Machine keeps sewing after foot pedal is off
Jan 24, 2009 | Sewing Machines
Sewing Machines Logo
80 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
