Question about Motorola Mobility RAZR2 V8 Cellular Phone
Network problem not connected with any network
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Nov 11, 2014 | Tablets & eReaders
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
How do i set up my hp laptop to wifi
Please Understand wireless network settings and setup:
Wireless networks depend on special-purpose radio receivers and transmitters that substitute the exchange of messages over the air for the exchange of messages that occurs over wired connections on conventional networks. When you power on your PC, Windows Vista automatically searches for available wireless networks.
The network icon in the system tray, shown in Figure 1, enables you to view a list of local networks that Windows Vista detects. Notice that the network icon in this figure is marked with a red X, which indicates no network connection is currently established.
Figure 1: A red X indicates no network connection is active.
When you click this icon, a window opens indicating you're not connected to a wireless network, as shown in Figure 2.
hpsmb_laptoppcwireless-fg02.jpg Figure 2: The detail window for the network icon provides a link to create a network connection. The window also includes two hyperlinks: Connect to a network and Network and Sharing Center. Click the Connect to a network link to open the Connect to a network window, shown in Figure 3.
hpsmb_laptoppcwireless-fg03.jpg Figure 3: Connect to a network window.
Nov 10, 2010 | Computers & Internet
My acer one netbook is stuck on aquiring network address
Hi Boyer,
I got your issue, Since it says accquiring network address.
If Your comp if its win 7 Operating system
1. Click on start go to control panel--> go to network and internet and then click on network and sharing centre
2. In network and sharing centre in the left hand side click on manage wireless network
3. In manage wireless network, you can see the networks which you have connected before , right click on the network name and select remove network. In the same way remove each one of them, the screen should me empty. there should be 0 items.
4. Then go back to network and sharing centre and click on connect to a network, you can see your network name , click on the network and click on connect to connect to the network.
If Your comp if its win Vista Operating system
If Your comp if its win XP Operating system
1. Click on start go to control panel--> go to network and internet connections
2. Then go to network connections
3: You can see wireless network connection , right click on it and go to properties and go to the wireless networks tab
4. In wireless network tab, under preferred networks, if you see any network , remove it and then push ok
5. Then right click on wireless network connection and go to view available wireless networks
6. here you can see the network and you can connect with your password.
Please try this, im sure this will work
Thanks & Regards,
Prema
Oct 09, 2010 | Computers & Internet
I have got a Toshiba Satelite L40 - 17U, Window XP and i can't connect it my laptop to my wireless modern. i also would like to clean it or maight say erase everything and install everything...
Hi Dacosta,
I got your issue that you have trouble connecting with ,
Thanks & Regards,
Prema
Oct 06, 2010 | Toshiba Computers & Internet
Having trouble connecting to an AT&T 2-Wire 2701 HGB Wireless Router (DSL).
Hi John,
I got your issue that you have trouble connecting with the At &t wireless modem ,
Thanks & Regards,
Prema
Oct 06, 2010 | Computers & Internet
Can not connect to hot spots, or wireless at college or library
If the icons indicate there is a Wireless Network Connection available but you cannot see any web pages, do the following to verify the correct, current DNS IP address is selected.
1. Right-click the network icon, and select Network and Sharing Center , select Manage network connection .
2. Right-click either the Local Area Connection or the Wireless Network Connection and select Properties .
3. On the Network Connection Properties page, highlight the Internet Protocol option, and select Properties .
4. Select the Obtain an IPv6 address automatically and Obtain DMS server address automatically options, and then click OK .
5. Returning to the Network Connection Properties page, on the Networking tab, select Configure .
If there is a Power Management tab for this device, de-select the Allow the computer to turn off this device to save power option.
6. Restart the computer.
The computer retains a list of all the networks to which it has been connected, and it tries to connect to the first wireless network it discovers in the physical area. You must determine if that is the network you want and if the connection is using the current IP address and password.
1. Right-click the network icon and select the Network and Sharing Center option. The graphic display indicates if there is or is not a connection.
oIf a list of available wireless networks is displayed, highlight any active connection and then select the option to Disconnect the computer from all the networks.
2. Now that all wireless networks are disconnected, manually set up a new wireless connection.
Do not click Connect to refresh a connection. If there was a problem with that connection, just clicking Connect will refresh the same wrong information.
3. On the Network and Sharing Center window, select Connect to a network , then select Set up a connection to a network , and then Manually connect to a wireless network and click Next .
4. When prompted, enter the required network information, and then click Next .
o Network Name (SSID)
o Security type
o Encryption type
o Security key or passphrase .
May 27, 2010 | HP Computers & Internet
Is there a manual shut off switch to disable the wireless search mode on an Acer laptop?
I assume you want to stop vista from automatically connecting to wireless networks other than yours.......try this:
Open Network and Sharing Center, click Manage wireless networks, click on your "home" network & make sure that Connect automatically when this network is in range is checked. Now do the same for any other connection that is listed but uncheck the Connect automatically when this network is in range.
Go to Start > Network > Network and Sharing Center
click Manage network connections under 'Tasks'
Right-click Wireless Network Connection
Select Properties.
In the Wireless Network Connection Properties dialogue box, click the
Wireless Networks tab.
Select other wireless network like "Y5ZONE", "PCCW" and click Properties
Click Connection tab
Uncheck the box "Connect when this network is in range"
Hope this helps.....
Jul 21, 2009 | Computers & Internet
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Motorola Mobility RAZR2 V8 Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
