Question about Dell P991 19" CRT Monitor
When powered on led comes on and then off. monitor is now black and wont come on.
    Sergeant:
  • 356 Answers
Hi. Try to run the diagnostics by turning the computer on, press F12 on Dell logo, select boot to utility partition and press enter.
If it doesn't have utility partition, then try to remove the video card and put it back in... then turn the computer back on.
If it still doesn't stay on, then you might have to replace your motherboard or buy a new desktop CPU.
Nothing is wrong with your monitor though.
^_^
Posted on Jun 06, 2010
2 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
Whenever there is a power outage, monitor wont power on, i have to wait for more than one hour. No LED light at all.
Your monitor probably detect a power surge when the power comes back and an internal protection is triggered to shut the power input. (breaker).
Try using a surge protector or a UPS.
Aug 08, 2011 | Philips 170S4FB 17" LCD Monitor
When turning on the monitor the LG logo come on and then a few seconds later ......It goes into low power mode and the screen goes black. Tried everything !
Make sure there is a solid connection between the monitor and the computer. Also, make sure the computer is on. The monitor won't power up completely unless there is a signal going to it. Also, see if the power pack on the monitor's cord is awfully warm. You may have an overheating problem and as a safety the monitor shuts itself off. If it is warm try plugging the monitor into a surge protector or different outlet. Don't use a power adapter that didn't come with the monitor. It may provide too much or too little power. If there is still a problem, contact LG. Hope this helps. Good luck.
Mar 03, 2011 | LG E2350T 23-Inch Widescreen Slim 1080P...
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
VG2230WM (Black, Gray) LCD Monitor: Will not power up, no LED power light...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | ViewSonic VG2230WM LCD Monitor
X9G NAGAIV goes black; can display, but wont.
Took it apart, all the way down to the boards and first examined the capacitors on the power board7d50dd4.jpg. It turns out it was a cracked metallized polyester film cap (C10), not a blown electrolytic capacitor. Ordered a new one and some transitors from DigiKey. Dont know if that is the complete fix, but the cracked cap certainly isnt supposed to be there.
Nov 10, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Can u help me? - Fujitsu-Siemens 900P LCD monitor burned out
Hi..there,
It's seems you got busted capacitors. Replaced all 5 capacitors in right handside with( 5*c8) in the 3-jpg photo power/inverter board.
Feb 03, 2009 | Computers & Internet
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Hi..there,
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Dell P991 19" CRT Monitor Logo
Alun Cox
