Question about LG DLE5955 Dryer
CHECK FILTER ALREADY CLEANED LINT FIRLET BUT KEEP GETTIING THIS MESSAGE "CHECK FILTER"
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
CHECK LINT SCREEN LED
check you air duct ,its can be bend or lint inside
Dec 20, 2014 | Dryers
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
Bosch Vision 300 series type WNB T80 - The dryer stops every ten minutes. I have to keep turning the machine back on. I have cleaned the lint filter (vacuumed out the lint filter area) and replaced the...
Do you use dryer sheets? The chemical in dryer sheets seal up the little holes in the lint filters. To test, take the lint filter to the sink and see if it holds water. If it does, give it a good scrub and toss out the dryer sheets.
Oct 29, 2013 | Bosch Dryers
I cleaned the lint screen an the vent, however I'm
Your are getting the clean lint screen message because the computer on the control board is sensing poor airflow so it thinks the lint filter needs to be cleaned. What else you would need to check is for lint build up in the blower housing below the lint screen or the venting from the back of the dryer for blockage from the back of the dryer all the way to where it exits to the outdoors for a possible birds nest or some other thing restricting airflow.
GENE
Sep 22, 2011 | Kenmore Dryers
GE gas dryer DSXH47GGWW- starts fine and begins to heat up then shuts off with a message that the lint filter needs cleaned. The lint filter has been completely cleaned and vacumed inside, outside and...
With no lint anywhere around the dryer the thing to check if havent already is the venting itself to see if outside it is blowing and not restricted or blocked
The control is sensing poor air flow and throws up the "clean filter" when air flow is restricted all be it from the filter clogged, or blocked/restricted vent
Gene
Aug 25, 2011 | GE Dryers
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
Dryer "clean lint filter" message
Hello. Begin by unplugging the plug on the dryer. Then pull out the filter and thoroughly examine the space that the filter slides into looking for any lint. Remove any lint that you find. Put the filter back and lastly plug the dryer back in.
These steps should solve the problem. If not, then the lint sensor has gone bad and should be replaced. If you wish to do that yourself you can go to searspartsdirect.com. Enter the model number of the dryer and then you will see the parts diagrams allowing you to locate that lint sensor, and even order a new one. Joe
Thanks for choosing Fixya!
Mar 07, 2011 | Dryers
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
Check Filer
hmmm..no lint screen means that you have lint buildups inside the machine...check the air lines, and in and out for the vents..first.
Mar 15, 2008 | LG DLG5988 Gas Dryer
LG DLE5955 Dryer Logo
276 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
