Question about Samsung SGH C450 Cell Phone
Trying to dial out gives message 'Conditional forwarding' then 'exit call'
  • 821 Answers
Hello,it could be a network problem from your service provider,so you will need to contact them to find out what the problem is,or you can as well scroll through your setting to se if your outgoing calls are not being barred.
please kindly rate the solution if it's helpful,
take care.
Posted on Jun 06, 2010
What do you mean by forwarding on conditional on?
Forwarding on conditional, means that calls can be forwarded to a different number (or voicemail) on certain conditions.
These could be, unanswered, unobtainable or busy.
Normally you would have this set to forward to voicemail if you are unreachable, or unanswered.
But you can forward ALL calls to a different number if you wish.
Please note that different phone providers can charge for this feature.
i.e. forwarding a call to your home number, they may charge you for forwarding.
May 12, 2014 | Cell Phones
How to deactivate conditional forwarding in samaung GT C3322? tell me the solution
Firstly type *#2767*3855# then phone automatically resetted and ur prob has to be gone
May 03, 2014 | Samsung gt-c3322 quad band dual sim...
How to deactivate conditional call forwarding
How to deactivate conditional call forwarding samsung c5212
Jul 23, 2011 | Samsung C5212 Cell Phone
Trying to change my name displayed on the LCD?
It's a trick. When we install Panasonic TDx systems, you have to give the phone users access to programming. If your installer gave you access, you can press PROG and dial **1234 and the system will let you into programming. By default, extension can usually do it, in our case, we allow it on all phones.
If you find the phone that can dial PROG ** (it won't beep at you when you start the sequence), program 004 is extension names. Dial it, press ENTER twice (it moves from softkey 3 to 4) and you'll be looking at extension 101 and a name if programmed. The NEXT key scrolls through the extensions and the keypad pressed X times to get to the letter and the right arrow key to step forward if you need to press the same number key steps you forward. The round ENTER key saves the new name, then pick up the handset and drop it back down to exit programming.
Carl
Jul 01, 2011 | Panasonic KX-T7630 Corded Phone
How can i block a number on a nokia 6500c my service provider can not is there any other way for blocking unwanted calls
The 6500c does not support conditional call forwarding (CCF) which is useful if your carrier does not provide blocking services. I have owned several nokia, a samsung, two LG, and currently have a blackberry 9330. If unwanted calls are a serious problem, consider upgradeing to a mobile phone that supports CCF. Conditional call forwarding can be used to forward any unwanted phone number includeing calls from unlisted, unknown or restricted callers. Depending on where you live, the call can be instantly forwarded to a service, such as trapcall.com, that unmasks the caller in addtion to providing the standard message "This number is no longer in service" for example.
Apr 25, 2011 | Nokia Cell Phones
Verizon blackberry tour froze, i took the battery out and it restarted but now i can only text and use the browser. I can not make or receive calls, i get an error message call forwarding conditional and i...
you will have to do a master reset this can be found in otions under security if running 5.0 it will be security wipe check all but the memory card and then hit ok then dial *228 choose option 1, if this does not work call *611 then choose option 3 for tech support if the phone is fairlly new they can replace it, they will have you try the same thing i just suggested and may resend service books to fix it. i had the same issue went back to my storm
Jan 17, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Conditional forwarding?
everytime i make a call
it keep popping up conditional forwarding calls
how do i cancel/
Aug 26, 2009 | Cell Phones
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Dec 17, 2008 | LG CE110 Cellular Phone
Phone disconnects shortly after dialing.  says" conditional forwarding"  then "call ended"
Call you cellular provider and sk for codes to disable conditional call forwarding, it should be something like *772
Dec 09, 2008 | Cell Phones
Samsung SGH C450 Cell Phone Logo
263 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
