Question about Autotek XS-900.4 Car Audio Amplifier
Autotek XS-900.4 stuck in protect mode
The amp will not come out of protection mode. All wires unhooked. even tried alternate power source. A new amp is installed to same setup as this and has had no problems. Help
  • 19,396 Answers
Hi.
The amp does not go on protection only because of wiring or power source problem , but also and mainly when there is an internal fault.
Protection is started whenever an out-of range voltage value is detected from the controller circuit.
Protection can be triggered from a burnt final IC or from a speaker wiring problem.
Since you have ruled out speake, wiring and power source problems, then this Amp is probably defective
If the Amp works fine on a different vehicle, then protection mode may start either because speakers impedance is not within Amp specs, or because the amp has a too big power draw. In this last case the problem is fixed installing a capacitor on the Amp 12V line.
Regards.
Ginko.
Posted on Jun 06, 2010
  • Ginko
    Ginko Jun 10, 2010
    Hi.
    I noticed that you left negative feedback.
    I spent time on your problem, and I will be grateful if you can change
    the feedback. The negative rating given will only affect the expert.
    Goodbye.
    Ginko.
    Problem Solver:
  • 17 Answers
If it's not blowing fuses, then usually you can eliminate power supply failure. I bet on a shorted output. Or outputs. 80% of these amps suffer from crappy solder traces to deliver power when needed.
Posted on Oct 19, 2012
The amp dont come on but power protecter light is red.
Sounds like something is shorting out and it is in protection mode. Check that the wiring is correct and there are no bad spots on the power wires. Unhook the power before starting your evaluation and leave disconnected until you think you've found the problem then rehook the power source. This will give the system time to reset if it needs to.
May 24, 2011 | Sony XM-2200GTX Car Audio Amplifier
Amp goes to protection mode. if the fuse is too small?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. . Double check all connections. Good luck.
A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Jul 15, 2010 | Autotek MM125.2 Car Amp
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
Autotek mm4000.1 locked it protect
try disconnecting the power and ground wait 30 mins then hook back up
Apr 12, 2009 | Car Audio & Video
KEEPS GOING INTO PROTECTION MODE
make sure that your running heavy enough gauge wire from the battery to the amp. make sure wires to bridge the amp is correct and the av wires from the deck are the right gauge should be like 8 gauge wires.
Mar 23, 2009 | Car Audio & Video
Keeps going to protection mode
My ? was answererd
im going to hook up a thicker ground wire and ground it to a better place.
my positive wire is as big as i could get and my RCA cables are the good ones
this is a great place yo get information. Thanks.
Mar 23, 2009 | Pioneer DEH-P3700MP CD Player
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Sep 28, 2008 | Autotek Car Audio & Video
Protection mode?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check your connections. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-mode-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
May 25, 2008 | Lanzar Car Audio & Video
Autotek amp
You got riped off if i were you i would go and get my money back because an amp like that cost around 399 to 499 dolars
Jan 24, 2008 | Autotek MX800.4 Car Audio Amplifier
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Autotek XS-900.4 Car Audio Amplifier Logo
280 people viewed this question
Top Autotek Car Audio & Video Experts
Professor_V
Professor_V
Tom Chichester
FastHarley
FastHarley
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
