Question about Sony Handycam DCR-DVD105 DVD Camcorder
"no disc" on screen with disc inserted correctly
I insert a TDK DVD-RW, turn on the vcam, press record button, and "no disc" appears on the screen. What can I do to allow the sensor to 'sense' that a cd is present???
  • kweku88 Apr 25, 2008
    Problem Solver:
  • 11 Answers
Remove battery to decharge internal capacitors for 8 hours
ought bring any software hiccup back to normal
also there might be a "reset hole' access with a pin somewhere on camcorder, try depressing
Posted on Jun 04, 2012
  • 10,594 Answers
Dear Kweku88,
Please check your camera with another mini-DVD. actually camera detects dvd with its dvd-lens. there is no other sensor to sense dvd inside.
Posted on May 26, 2008
When I insert a blank DVD+R to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
some discs don't work in some recorders. I always use verbatim, ritek or tdk discs and have very few problems. if the recorder suddenly dislikes a batch of one brand, I'll use one of the others.
Jan 29, 2015 | GoVideo VR3930 DVD Player/VCR
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
When I hit the "Record" button, the recorder says "No Audio" - and I'm using TDK CD-RW disks ... any idea how to fix this ???
The disc has to stay music on it on the label. Ones you use for a computer to burn music will not work with a CD Recorder,
Dec 01, 2012 | TDK DA-3826 2-Disc CD Recorder
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Apr 25, 2010 | Televison & Video
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
4x can be used
8x will result in a disc error.
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
The following are brands of discs we DO NOT recommend:
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony Handycam DCR-DVD105 DVD Camcorder Logo
82 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
