Question about Kitchen Appliances - Others
I have bought a bda900 combo charger to charge my 7.2volt 1700 mah battery for my rc car. I am unsure of the settings for peak and fast charge. If i use charge leads off of a 12v car battery its charged in 20 mins, can you help, Mark
SOURCE: Sony PSP not charging
ok heres what you do 1. try blowing in the adapter slot 2. take out the mem. card & the battery for 24 hours 3. buy a new psp
Posted on May 02, 2007
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Posted on Nov 18, 2008
  • 3 Answers
SOURCE: 12v battery powered barbie jeep
If you are comfortable with wires then go to walmart and get a schumaker battery charger from the automotive department. either the Maintainer or the next one up I think ist is model 600 They are much better than the stock chargers because when the battery is full they automatically switch over to float mode so the battery doesn't get cooked. www.modifiedpowerwheels.com has lots of info on exactly what you would need to do. The chargers are 20 and 30 I believe and they can be used for other things like lawnmowers and car batteries if needed.
Posted on Dec 18, 2008
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
  • 3 Answers
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Posted on Feb 22, 2010
Which AA battery shall I buy for my digital camera? 1500? 1000? 2500?
Although you could use these, do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights. The lower capacities suggest NiCd batterie. Also don't use these.
A set of new NiMH batteries, from 2000 to 2600 mAh with a good charger, will be fine.
Two things.
There are very fast chargers around. Don't invest in them. I payed 80 euro for a quick charger. Could charge 2700 mAh batteries in 15 minutes. The charger killed all my NiMH batteries I had (more than 40) It took me till the fifth or so died, before I realised it could be the charger. Since I stopped all my batteries one by one died and I had to replace them all
I now have some "fast" chargers that take 2 to 3 hours and the new batteries Can handle that.
Better buy a slower charger and some good batteries, than the other way around.
Second. Test the 2600 mAh batteries, if they fit.
To put more capacity in the "same" AA battery some brands made them slightly thicker. So it could be you can't get the largest ones in your camera.
Mar 21, 2015 | Cameras
I am wondering if anyone could help me please, i have bought some 2600 mAh AAA batteries for my video camera. I was wondering what kind of battery charger i would need to get to recharge these batteri
Any charger that will charge AAA batteries should do the trick. I have several 2600 mAh batteries, and use chargers from RayOVac, Nuon, and others without any problem.
Jan 30, 2015 | Cameras
I am wondering if anyone could help me please, i have bought some 2600 mAh AAA batteries for my video camera. I was wondering what kind of battery charger i would need to get to recharge these batteries?...
You dont need anything very advanced. 2600 is a nice high capacity for Ni-MH AA's and 1100 is really high capacity for AAA's. Here is a little panasonic charger that would do the job just fine.
Panasonic BQ CC17SBA eneloop Advanced Individual Battery Charger with 4...
I have been use sony cycle Energy Rechargable batteries AA 2000mAh. They are properly charging. But now I'am purchased another sony cycle Energy Reechargable batteries AA 3000mAh. But they are no charging...
It's likely your charger. You probably own a "fast charger" but it's also probably designed for your lower mAh power batteries. The charger does not understand the power difference of your newer high-capacity battery, thus it is automatically stopping the charge before completion sensing something is wrong. You'll need to either purchase a newer charger, clearly stated capable of charging 3000mAh batteries. An alternative is to use an older "trickle" charger (one of those that charges at very low power slowly overnight). These don't automatically turn off when the battery reaches full charge, thus will charge your battery.
Sep 19, 2010 | Cameras
How long do I charge my boat
All depends on the size of the battery and the charger youre using. Standard batteries are 7.2v on these boats pictured. You will have to check the mah which is on side of battery, if its 1800mah and youre charger charges at the rate 500mah you should charge it for 4.3hrs.
Mar 07, 2010 | Hydro Slide Radio Remote Control Hydro...
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
Doesn't work!
I've gotta solution1.gif for you. I had the same problem and what I have found out is that if the headset4.gif does not go charged for an extended period of time, the battery needs to get a kick started so that it will accept a charge. In order to do this, you have to remove the blue plate with a small screwdriver first. Then with an extremely small torx bit take off 2 screws that were under the blue plate. Next remove the board from the shell, but not so much as to disconnect them from the soldered components.
Here's the tricky part. You will see the 150 MAH NiMH battery with a + and - post right on top of it. the connections are about 1/8" thick. You MUST HAVE a battery charger that can manipulate the current and voltage while charging. This would be like a peak charger for an R/C car of which I happen to have. The Jabra battery is NiMH and you should be able to set it to that instead of the NiCd. Set it at 150 MAH, and Delta Peak at Auto and in 10 minutes its charged and ready to go. After you put it all back together, you can then again charge it as you normally would with the AC charger or USB connection. I believe the majority of DOA headsets4.gif are due to being on the shelf for an extended period of time and not getting some charge.....eh it happens!
Gerald
Dec 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Bt350
I've gotta solution for you. I had the same problem and what I have found out is that if the headset does not go charged for an extended period of time, the battery needs to get kick started so that it will accept a charge. In order to do this, you have to remove the blue plate with a small screwdriver first. Then with an extremely small torx bit take off 2 screws that were under the blue plate. Next remove the board from the shell, but not so much as to disconnect them from the soldered components.
Here's the tricky part. You will see the 150 MAH NiMH battery with a + and - post right on top of it. the connections are about 1/8" thick. You MUST HAVE a battery charger that can manipulate the current and voltage while charging. This would be like a peak charger for an R/C car of which I happen to have. Set it at 150 MAH, and Delta Peak at Auto and in 10 minutes its charged and ready to go. After you put it all back together, you can then again charge it as you normally would with the AC charger or USB connection. I believe the majority of DOA headsets are due to being on the shelf for an extended period of time and not getting some charge.....eh it happens!
Gerald
Nov 21, 2007 | Jabra BT350 Wireless Headset
Kitchen Appliances - Others Logo
50 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
