Question about Motorola Mobility W375 Cellular Phone
Unable connect phone to PC
How to connect motorlola to PC , need to connect net in PC through motorola W375
I need a pc suite for motorola v365 so how can i get the softwear of pc suite and net connection for my cell
http://www.software112.com/products/motorola-pc-suite.html
From the above link you can download the pc suite for your phone.It sizes about 102mb.
Install it and follow instructions in it to connect your phone
Jan 02, 2011 | Motorola Mobility W375 Cellular Phone
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
How a i get motorola net connect software
if your phone is compatable for net connect then call to costumer care of sim card which you are using. they will send you settings of net connect.
Tenzin
May 11, 2010 | Motorola Mobility W375 Cellular Phone
I can not contact the net by my motorola in pc
Here is the link for the USB Drivers:
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=bda09ec8009a0210VgnVCM1000008806b00aRCRD
Here is the link for the Motorola Phone Tools Utility:
http://lfiles3.brothersoft.com/internet/mobile/Motorola_mobile_phone_tools4.5.1.zip
Please give me a big thumbs up when you rate my answer. Thanks!
Jan 18, 2010 | Motorola Mobility W375 Cellular Phone
Need free unlock codes for Motorola W375 Net 10 cell
wanna unlock ur mobile, here i found a site this is not free of cost but reliable , and i found this last week i used this nice...to unlock
http://www.mobile-unlocker.com/
May 15, 2009 | Motorola Mobility W375 Cellular Phone
Motorola W375 won't charge online!
You'll need pc charging drivers to charge your phone with a pc and a USB cable, you can get the driver at the motorola website.
hope this helps.
Mar 31, 2009 | Motorola Mobility W375 Cellular Phone
Unlock motorola w375 net 10 prepaid
just download "Motokit "software.& install it in ur PC.Select Data/fax mode in usb setting of ur mobile.
then open the MOtokit software & connect ur phone..Software will automatically detect ur phone.
then of top left side of the software select " mobile" & then"info"..it will give u the Unlock code & security code of ur mobile...
Nov 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How do I connect my Motorola w375 to PC
try downloading the motorola usb drivers and installing them.
i would try that first.
you could also get motrola phone tools software which comes with the drivers and can transfer the photos from your phone
Apr 12, 2008 | Motorola Mobility W375 Cellular Phone
Downloading photographs
Make sure the phone is switched on at the "home screen" with the flip open.
Connect the phone directly to a USB socket on your computer.
When the phone displays "Connect phone as external storage device" select "yes" & wait until the screen on your phone goes white.
On your PC, go to My Computer & select the new item MS DEVICE. Click on pictures - here you will see your photos & you can drag & drop them to your chosen location on your computer.
Feb 15, 2008 | Motorola Mobility W375 Cellular Phone
Motorola 375
I have no solution to this problem as I am having the same problem with my Motorola W375. I do have a question for you people though. What manual are you reading from that says the W375 can connect to your computer for downloading anything? Every W375 manual I have seen says nothing anywhere about this mystical ability you believe exists. Please enlighten me.
I would still like to know if anyone finds a solution to the 'Unable to Charge' message, but please also let me know about this brochure that says you can connect to your PC with no driver. Very interesting.
Dec 28, 2007 | Cell Phones
Motorola Mobility W375 Cellular Phone Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
