Question about Sony NWZ-E438F Digital Media Player
Cannot get it to turn on, it wont charge when hooked up to comp.
When i have it connected to the computers usb port it wont turn on like it used to and begin charging, When i hit the power button it will pop on then go off right away.
  • 105 Answers
Have you check the cable if its working try another cable to connect it to your computer and see if it'll work, if problem still exist find a local electronics repair shop and let them have a check on it.
Posted on Jun 06, 2010
Monintor does not read sd card or usb with inserted on monitor.
you need to connect a usb cable on it and attache the otehr end on the usb port of the comp
Mar 03, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
I bought the sony reader prs-300 for my girl on christmas 09
1. Connect the Reader to a different USB port of the Computer.
2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp.
3. Disconnect the Reader and then press the RESET button.
4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly.
5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Feb 07, 2010 | Sony Reader Pocket PRS-300
When you plug the reader in to recharge is a red light supposed to come on until charged? How do you know when it is fully charged?
Yes, the red light should be turned ON after connecting the Reader to te Computer. That means the Reader is taking charge. After getting it fully charged, the red light will be turned ON. If those things will not happen to your reader, perform the below mentioned stepos::
1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Feb 02, 2010 | Sony E-reader Portable E-book MP3 Player
Wont Charge
Yeah, I had this problem too because I was connecting the USB proprietory connector/cable at the front USB drives on the computer. If you have been using front USB connecters, try using the back USB drive connecters.
It worked for me :)
Apr 12, 2009 | Sony NWZ-E436F MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Dec 03, 2008 | Magellan Maestro 4250 GPS
Infitek shuffle ipod
Greetings bernince24,
Generally when an Ipod is charged, it is off and connected to a usb port with your computer. It simply draws power off the computer. It is all pretty intuitive, plug and play. Meaning the once you hook the ipod to whatever charging device you are using, it will charge on it own from there.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Apple iPod shuffle MP3 Player
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Sony NWZ-E438F Digital Media Player Logo
180 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
