Question about Ariston Technologies AWD121WH
When the machine on it showing f-01 - Ariston Technologies AWD121WH
  • Ariston Tech... Master
  • 12,061 Answers
Tilt the washer back and support it with wood blocks so you can remove the kick panel screws and get the tech sheet from inside.
F/01 is an EEPROM error on the CCU. A power glitch may cause this error; unplug washer or disconnect power for two minutes. If broken, then you'll need a new CCU-- not a rare event on this washer.
s there a link to the diagnostic test for the washer? I found the one for the dryer here:
http://fixitnow.com/wp/2007/06/19/whirlpool-duet-sport-dryer-diagnostics-and-fault-codes/
Posted on Jun 06, 2010
I cannot set the time and date on my cash register when I turn key PGM it shows "ae 01" and no 000 what do I do?
Error 01 means that a previous activity has not been completed. Here is a link to the manual: http://totalpos.co.nz/wp-content/uploads/2012/10/Casio-TE2400-Operator.pdf
May 10, 2015 | Casio TE-2400 Electronic Cash Register
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Hotpoint ultima wt741p is showing F:01 on the display screen when the machine starts up -the machine starts but no water comes through and the drum stays idle - any advice please ????
F:01 is display say some error problem occur in your machine, maybe the motor that pump water to fill the machine has not working or its sensor that water is flowing is not working also.
Jan 29, 2011 | Hotpoint Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Machine powers itself on-off / Error code F-01
I would try to find out what the "F-01" means but if you need to replace circuit board they normal are easy to "unplug and replug" wires. But SEARS tech's would be best to repair. If can't find a source to tell you what F code stands for , call SEARS service and when he diagnoses problem you could see or ask him how to replace my tech is helpful that way, then it only cost the "service casll" rate and not hte return part replacement cost also
May 19, 2009 | Kenmore HE2 Plus Front Load Washer
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
Xerox F110 Fax Machine shows a status code 01 on the transmission report. what does it mean
the manual says it is the destination machine not answering.
Are you sure your phone line has a dial tone? Check that.
But 01 one means the machine is not connecting to the other after dialing the number. That does not mean you have a dial tone on the line.
May 02, 2008 | Office Equipment & Supplies
Xerox Phaser 6110
What you are listing here is the date and time refoected on the screen. Not a fault code . What this post is quoting is that the machine reset the date and time to default.
When you work around the screen see if there is another fault showing.
Feb 20, 2008 | Xerox Phaser 6110 Laser Printer
Ariston Technologies AWD121WH Logo
298 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
