Question about Gateway FPD1975W 19" LCD Monitor
Gateway FPD1960 monitor
I have a gateway FPD1960 monitor that will not I have a gateway FPD1960 monitor that will not power on. When you turn it on, the power light flashes, but no display, then you cannot turn it off with the front panel power button. I have taken it apart and believe it to be the inverter. The caps look like they are "crowning" on top, but our local More I have a gateway FPD1960 monitor that will not power on. When you turn it on, the power light flashes, but no display, then you cannot turn it off with the front panel power button. I have taken it apart and believe it to be the inverter. The caps look like they are "crowning" on top, but our local radio shack does not have the caps in stock. Does anyone know where to get a replacement inverter?
Comments: Jun 06, 2010 - Thanks for the reply. I received and replaced all 9 caps (5 of the 470 and 4 of he 220 micro farads). I turned the monitor on and it seemed 'normal'. I got the no signal box, then I connected it to my laptop and the screen appeared. The it stated it was going to Auto Adjust, then it went blank. Now, the power light is on (I can turn it off), but nothing else is showing. When I disconnect the vga cable I do not even get the "no signal" box. If I unplug it and then plug it back in (with it connected to my laptop or desktop) the screen will flash very quickly (and I can tell that it is showing the what it should be, but then goes blank again. What is next to look at? Thanks.
See less
  • Gateway Master
  • 12,061 Answers
Support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Posted on Jun 06, 2010
Monitor blinks after sleep mode
The most common cause of flashing or wavy display is a weakened or failing power supply caused by bad capacitors. This is easy to repair. Here is a link to repair information for the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_30&products_id=206
I hope this helps, if so please rate my solution.
BuddyMc
Feb 19, 2012 | Gateway FPD1960 19" Flat Panel LCD Monitor
I have a gateway that is plugged in but continuously reboots
bailerie, Gateway and most all other LCD displays DON'T know how to reboot! They have NO need to do that! You must tell me what you see when you RECONNECT FPD1960 to a already fully booted, KNOWN GOOD pc that is currently displaying the WIN-desktop! Then and only then power-up the 1960 unit and observe what is going on and for how long! The only guess I can make about this problem is this. The "switch-mode-power-supply" inside your monitor is cycling IN and OUT of SHUTDOWN MODE because it has detected a FAULT of some kind with another circuit or even with itself. Get back to us so we can further help you. 12fixlouie Bye for now.
Nov 07, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Where to get LCD Lamp?
Your problem may not be a lamp issue at all..it might be a power board problem.
May 28, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Where do I buy parts for gateway fpd1960
I'm sorry to say that in today's electronics devices, there is not much support anymore when It comes to service parts.
In many cases the same boards have to be fixed if you want that device to be functional again.
Mar 03, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
No Display
try it on another p.c. My lg moniter did that and it was my video card
Feb 03, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
279 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
