Airwell Spilt Level system does not respond to use of remote and can only be operated by manually switching on and off.
    Problem Solver:
  • 7 Answers
When you press a button on the RC, does a arrow appear in the top right corner of the RC?
Posted on Aug 10, 2010
  • tony24g Jan 02, 2011
    I have the same problem,and yes when I press any button on the remote ,I get the arrow up in the top right corner of the remote.
  • John Plowes Jan 22, 2015
    have same problem, arrow appears every time I push a button but air con does not respond? Please help
Mine stays on even when i used to RC to switch it off. Fan control/mode function is fine though, it just doesn't respond to the RC for on/off function. Please help
Posted on Jul 27, 2013
Help mine is the same ;-(
Posted on Jan 12, 2013
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
System will not switch from pool m ode to spa mode. I use the remote control and it says the spa mode is on but the pool mode continues to function
First check to see if the valves can be operated manually. There are tiny switches on the side, end or underneath of the automated valve actuators that can be switched to operate the valves manually. With the power on and with the switch in the center position the operator should not move. In the other two positions the operator should move the valve to one limit or the other. If you cannot get either operator to function manually this way then there is likely a problem in the control system. If you still have a problem feel free to respond send me the results and I will respond with more things to do. I hope this helps.
Aug 12, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
Reprogram airwell remote to show deg c and other functions
To change into degrees Celsius, open battery cover and you will find four dip switches. They are numbered one to four. You will need to switch number three off and then reset the controller. Reset if performed by holding the "SET" "CLEAR" "HOUR UP" and "HOUR DOWN" buttons until the display clears. The remote should now be in degrees Celsius. Below is a part of the manual that I have regarding dip switches:
SW1, SW2-Selection of Reverse Cycle or Cooling Only ModelSW3-Selection of degrees Celsius or degrees Fahrenheit SW4- Selection of time displayed in 12hr or 24hr format.
Hope this helps
I take the time to help, so please rate me
Jul 03, 2010 | Heating & Cooling
I need to know where i can get a manual on how to set the remote controll for the air conditioner. right now we are turn them on and off every day or when it gets to hot or to cold. i would like to set...
If its for the unit pictured go to http://service.airwell.com.au/airwellsanyoparts/Website%202007%20update/airwell/XV26RCA/ and click on operation instructions.doc. Even though this is an airwell manual, they both use the same control.
Hope this helps
Mat
Jul 15, 2009 | Sanyo 18KHS72 Air Conditioner
Remotes won't work
There is a reset button in your remote try to reset it then try the remote to your unit. If it wont work then the receiver board is defective.
Jan 04, 2008 | Heating & Cooling
Lg airconditoner remote contol n98
Open the front grill of the indoor unit. Check on right hand side for a forced operation switch. This switch is for selecting of either manual operation or remote or auto, select remote, then try. You can also press the reset button on the remote, under the cover with a pen. Hope this helps
Oct 09, 2007 | Network Computing Devices NC900 Network...
Heating & Cooling Logo
506 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
