Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
The machine keeps showing test. it won't go onto any other programme. it keeps running through the test programme then stops, i then try and put it to wash and it will come up with test again.
  • Hotpoint Master
  • 12,061 Answers
Http://appliancejunk.com/ge/washer/31-9103.pdf OK, to help you, I have found you your service and troubleshooting manual. Below is a DIY self help. washer link, this will help you to troubleshoot your issue. http://www.acmehowto.com/howto/appliance/washer/washer.php
You should try to reset it, but if that doesn't work, you may find you have a main controller board failure.
Posted on Jun 06, 2010
Husquavana Rose sewing machine keeps stopping. Stitch is good, threads move with appropriate tension. But a spool of thread symbol keeps showing up and blinking just as the machine stops. How do I fix
hi have you checked the bobbin some times this is the problem always remember when putting your bobbin in the machine alway put it in the shape of a 9 it runs better putting it in the shape of a p can cause it to stop or break the thread i hope this has help you .
Jan 02, 2018 | Sewing Machines
G'day to you. We have an AEG OKO lavamat 88840 update washing machine. Today we put it onto a 40 deg programme, using the Time Saver function. After approx. 5 minutes, it stopped mid-programme, with...
Check your pressure sensor. Make sure that the air column that operates the pressure sensor is not blocked. Find the pressure sensor and remove the air hose to it. Blowing into it with the hose attached to the pressure sensor will check the pressure sensor. Use an ohm meter to measure if it changes. Blowing on it with it connected to the air column will check that nothing is blocking it.
Nov 08, 2017 | AEG Washing Machines
The washing machine will run a complete cycle perfectly, when i then empty it and refill with dirty washing, i put it onto the programme and press start, the machine sounds like the motor is running to...
On some machines when you start a programe the pump may run for a short while Restart machine and just give it a try for 3/4 minutes first just incase.
Sep 15, 2010 | Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
I have a 6 year old Zanussi model FJS 1025 W.
hi
it looks like the electronic programmer it is not being read past that point.
suggestion get the programmer dynastic tested, some programmers can be reprogrammed or replace with anew one
Dec 21, 2017 | Zanussi FS1055W Front Load Washer
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
