Question about X2Gen MG19MY 19" LCD Monitor
The buttons on the front of the monitor dont seem to work.
The buttons don't work (power, menu, volume). Have to unplug to turn it off. And when you plug it back in the volume adjust is in the center of the screen for about 5 minutes then goes away.
  • 1 more comment
  • Flbound1 May 20, 2008
    I experience the same problem, only my buttons are on the bottom and not the front. I unpluged the external power supply from the power strip and pluged it directly into the wall. Problem seems to be solved.
  • Ajemy  Rashid
    Ajemy Rashid May 11, 2010
    Do you mean the screen blackout?
  • Ajemy  Rashid
  • 180 Answers
Try to check the main board of LCD.
Posted on Apr 19, 2008
Osd Lock how to open?
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! ...
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
Mar 07, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
Cant get my monitor back in english its on *** i think
restore your settings to "Factory Settings" by
use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
? Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
Jan 06, 2011 | HP w1907 LCD Monitor
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Apr 15, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Dec 23, 2009 | HP 22" Widescreen Flat Panel TFT LCD HD...
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
No menu
One of the buttons on the front of your monitor is probably stuck.
(Only one of the buttons work at a time on most monitors)
I cannot recommend taking it apart your self (have a tech do it)
But take off the front, check the buttons after you take off the front, and if it still occurs unplug the buttons from the monitor.
If it stops (which it should) replace or fix the controls)
If it doesn't, call an exorcist (just joking) or buy a new monitor.
Mar 14, 2008 | iiyama Prolite E430 17" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
116 people viewed this question
Top X2Gen Computers & Internet Experts
William Alequin
Ed Mac
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
