Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
What is tool to buy to connect refrigerator to water supply in house.
  • 54 Answers
If you are taling about tool thast hooks to water line under the sink you use a peircing tool that you can buy at any harware store for about 5.00 it fits on the cold copper line and when connected. tyou turn in to peirec the line and it remains on the line.
Posted on Jun 06, 2010
Water dispenser on my Kenmore side by side refrigerator not working. It came with the house with no manual. Model number: 253.54333300 What should I do?
First check behind the fridge or in the basement that the water supply to the fridge is turned on or if it's even connected. the water is supplied by a flexible Poly 1/4 inch line. They are quite often connected to a saddle valve that straps onto your water supply pipes. That valve may be shut off. If when you press the lever in the door you can hear a "gathunk" that's the solenoid trying to open. Try the water supply first though.
Oct 28, 2017 | Kenmore Refrigerators
Kenmore Elite 795-78029. Why do I have water spraying from behind the supply line connector on the back of the refrigerator?
the valve or its supply line is leaking --damaged or loose connection if your able to isolate the problem say its the valve you can change the valve with simple tools same if water line can buy a repair kit
Aug 11, 2015 | Refrigerators
Refrigerator no make ice
You could have 3 possible problems. 1---icemaker is bad and needs replaced. 2---possible blockage in the water supply from dirt or particles. Check water flow at line where it connects to the refrigerator. 3---the water inlet valve could be bad and not letting water into the icemaker. This is the valve the house water supply connects to at the back of the refrigerator. If bad it needs replaced.
Jun 02, 2015 | Refrigerators
Frigidaire professional series refrigerator leaking water under door
Hello - Typically when water is coming out from under the refrigerator there could possibly be a loose connection from the house water supply line to the water valve or a cracked drain pan (located underneath the refrigerator). Try confirming that the valve is tightened. If the connection is still leaking, turn off the water supply valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. There could also be a loose water connection to the door. This connection is located on the bottom left of the freezer door.
Sep 25, 2012 | Frigidaire Professional Series PHS68EJSB...
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
I just received my new Whirlpool side-by-side refrigerator with in door water and ice dispensers. How do I connect the water to the refrigerator?
Connects at back of fridge. bottom left corner you will see a compression fitting, you need to connect to house hookup. If you had it delivered they should have hooked it up for you, unless you don't have a house hookup behind fridge. Then in this case you would need a plumber to run water to fridge. Or you can buy a kit at lowes or homedepot and do it yourself.
Sep 27, 2010 | Whirlpool Refrigerators
Where do I find the water filter it needs repacing?
Water filter is a long cylinder - virtually the first thing connected to the supply pipe at the back of the unit.
I advise you to buy a replacement first - then you will know what tools you need to remove it - and what to look for.
Oct 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
We have a ge side by side refrigerator...while moving it we broke something off the back...it was like a little tube or coil...it was really short..maybe 4 inches...i think it led to the icemaker...i dont...
Possibly the water inlet valve? Look at the water line on the back that goes up the back to the ice maker. The bottom end should be connected to the water inlet valve. This is also where the water supply from the house connects.
Oct 02, 2009 | GE Profile PSI23NCR Side by Side...
Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Dec 01, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
