Question about Samsung Washing Machines
What is mean Uc error in samsung washing machine
Re Check power
By sami Bhagalpur
Posted on Oct 12, 2012
Hi how to fix error Uc samsung automatic.?
Posted on Feb 13, 2014
4 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: What is mean Uc error
Hi
If you are sure that the error code is UC not UE then it means unbalanced condition & indicates an issue with either the clutch assembly or the control board that is bad. You can leave the washer unplugged for 15 minutes to see if the error returns. Please post back with some more details about the issue for further assistance.
Daniel
Posted on Sep 18, 2011
  • 6277 Answers
SOURCE: I have a Samsung Automatic
As it's only 2 days old I suspect it has not been installed 'balanced'. If what follows does not cure it CONTACT YOUR VENDOR. Anything else could invalidate whatever warantee/guarantee you have!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
SOURCE: samsung b1245s washing machine
Error code is actually 5e and is to do with your drainage being blocked. Check the flap in the lower right of the machine. Open and unscrew the big black wheel/cog thingy (make sure you get lots of towels or drain all the water first with the little pipe to the right of the big black wheel/gog). I found a few coins trapped in my pipe and its working a treat now I cleared them out and spent them on lots of sweeties. Yummy. :D
Posted on Aug 19, 2008
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Please how do I resolve error code UC on my Samsung diamond drum washing machine?
Washing machines have computers. They are literally designed for no ''DIY.'' Error code would likely mean ''new computer needed.'' Either way, you need a laptop with a factory testing program installed in it That's how these guys work nowadays. The laptop tells them what to do next, and you (and I) can't have one.
Aug 15, 2015 | Samsung Washing Machines
My sumsung washer is showing an error (Uc) dont know what to do with it, if you have a solution it will be appreciable.
The UC error code represent a malfunctioning main PBA or a power fault related to an electrical power supply that is incompatible with the Samsung washing machine.
Contact Samsung service department!
Jan 02, 2015 | Samsung WF337AA Front Load Washer
Vibrating and banging
Feb 13, 2014 | Samsung Washing Machines
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
What is mean Uc error in samsung washing machine WF8550NHW model?
my samsung washing machine paused becuase of the power voltage is not instable. what should i do?
May 12, 2010 | Samsung Washing Machines
What does the code "UC" mean? The "U" is half as tall as the "C"
It is related with the improper balance of the machine or a problem of the sensor. You can get a full explanation about this error here:
http://appliancejunk.com/forums/index.php?topic=2003.0
May 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have an error code uc in the spin cycle what could be causing the problem?
uC = a continuous unbalance condition of the wash load.
Because you are posting in the Fixya Neptune FAV6800AW Top Load Washer forum I’m going to assume your machine type is a FAV6800A or FAV9800A.
For those machine types I feel you are experiencing a clutch malfunction. Can you confirm the machine model number and let me know if you want to try a DIY repair. You only need basic hand tools and skill sets to repair. See this post for what is involved and this a most recent post of a forum members repair for a dC error code condition in Spin Cycle which related to the uC error code in Spin Cycle.
Dec 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Uc code error
uc code means unbalanced condition. My research shows this as being an unbalanced load or a faulty control board.
Make sure your load is balanced, otherwise you may have to replace the control board.
Jun 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
4,593 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
