Question about HP Computers & Internet
HP Pavilion dv6850ee Notebook does not starts. When power button hit, light glowing and hard-disk reading. But, immediately gets shut-down. After starting of this problem, one time it worked and I got into Windows. But unable to start after that shutdown. Thereafter it never entered or booted to Windows and It shows the same problem. What could be the cause and any solution???
    Scholar:
  • 58 Answers
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf
Refer page no: 53 & 54
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
If the issue persists after the above steps, then this could be due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. If your notebook is covered under HP Standard Warranty, then I would request you to contact HP Support to get your notebook repaired under warranty.
I believe the information provided would be helpful to isolate the issue with your notebook.
Posted on Jun 07, 2010
Change boot order hp
DON'T FORGETT F9 TO SAVE CHANGES.
NOW REBOOT.
Jun 04, 2014 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP Garden Dreams Pavilion dv5-2129wm problem.
You killed the hard drive. It needs to be replaced and you'll need a new operating system to go with it.
Sep 02, 2012 | HP Pavilion dv5020us Notebook
When I hit the power button on my HP DV9000 it lights up as if it is powering on, then immediately shuts down. Any ideas?
Hi. It can be caused by many things like. Short circuit (Check all the connections) Maybe you dropped or hit your laptop The mother board is damaged if you still have the warranty call HP.(800-474-6836) Somehow the bios got corrupted, the solution to that can be restoring the Pc but you will lose all the files in it to do this press f8 or f10 when it is starring and follow the recovery steps.
Hope it helps. Good luck.
Aug 31, 2011 | HP Pavilion dv9000z Notebook
Computer will not turn on. All lights will light up when pressing power button but then shuts down immediately.
Did you change any settings in the Bios?
If so this could cause an issue and you will have to reset your cmos.
Jun 14, 2011 | HP Pavilion dv9000z Notebook
During reformat hp pavilion dv6-1251nr reboots and the screen goes blank, har drive seek light goes out
Shut down the computer.
Turn on the computer tapping F10 key on your keyboard.
You will see BIOS comming up.
Go to the option SMART and Run HDD Self Test.
If it passes then get another set of recovery disk for HP Pavilion.
If test fails, replace hard drive.
Dec 02, 2010 | HP Pavilion dv5-1251nr Notebook
I have a hp pavilion dv5 notebook, my hard disk makes some funny sounds, doesnt boot to windows, i get this message harddisk (3f0). i can recover my files from the disk
Hi
you could try to hit the delete key when starting up the computer i think in there somewhere is an option to check disk to see if there is errors on it as i think it sounds like thats the problem
hopefully you have already saved any photos or files on cd ???
You could also take the hard drive out of the laptop then replace it to see if that helps it has been known to work
and you could try to restore back to factory settings by hitting the F11 key several times which the laptop is starting up if none of these things work then you may have to buy a new hard drive
I found this on another site which may be worth a read
http://www.ehow.com/how_4814366_boot-hp-recovery-partition.html
Nov 18, 2010 | HP Pavilion dv5-1000us Notebook PC
Lcd is black on start up only after closing lid. HP dv9000
first do a hard reset that disconnect the ac adoptor and the battery form the notebook and press the power button for 30 second and then only connect the adoptor and power on the notebook as the notebook boot up get connect to the internet to the hp.com site and do a bios update on the notebook
Mar 12, 2009 | HP Pavilion dv9005us Notebook
HP 6227 BLANK SCREEN
LINK
The HP DV6000 has problems that HP is aware of. Check to see if yours is eligible for free extended repair.
May 10, 2008 | HP Pavilion dv6000z Notebook
Start up error
see this problem with your hard disk pls take a back up of your hard disk and replace the hard disk immediately
Oct 09, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
