Question about Symphonic ST419E TV
I have a 27 inch black Symphonic t.v model wf2702. with this t.v I having been able get a picture with my Apex dvd connected to the t.v.could you please hlep me withthis
  • Symphonic Master
  • 12,061 Answers
Www.symphonic.us/pdf/spec/2004/ST419E.pdf
Please find a user manual above, and a service and repair manual below.
http://elektrotanya.com/symphonic_st413e_st419e.pdf/download.html
You need to check, that BOTH units are set to correct video format, IE: NTSC of PAL. The Connections are wired up correctly, the Correct External INPUT has been selected on the TV. Remember you do NOT use "Channels" to view Externally connected devices. You always wire color to color on both ends of the equipment. Please follow the manual.
Posted on Jun 06, 2010
I have a symphonic 27 inch tv and need the code
Google the model number of remote and the set for "manual" which should have possible codes.
With the manual for the remote look to see if it has a search mode which will allow you to try every possible code one at a time to find one that works.
Universals even if programmed will be missing key features the original remote had.
Apr 23, 2012 | Symphonic wf27f4 27 inch Flat panel TV
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
My tv is locked
It sounds like the manufacturers are asking you to get it looked at by an engineer! Try their website, maybe they will have a firmware download or a key combination that can be pressed to force the system to re-boot when powering up, something like the sky+box has. Try and press the channel up & down buttons while pressing the on button, or maybe it'll be another combination, it's worth experimenting before you get an engineer out. Hope this helps
Jul 17, 2009 | Apex Digital AT2702 27" TV
No remote, need code for universal remote
Try this method:
Turn on the device you want to program.
Press and hold CODE SEARCH until the indicator light lights then release code search.
Press and release the device button you are programing TV, the indicator light will blink once then remain lit.
Press and release OFF/ON until your device turn off.
you may have to press upto 200 times
When your device turn off press enter button the indicator light will go off,good luck.
Jun 02, 2009 | Symphonic WF20D4 TV
No tv remote
Go to Radio Shack and get an universal remote control, mine is a Phillips Universal and just program it to your tv. It has a tv/vcr input to let you switch to the right "input"/channel.
Sep 11, 2008 | Symphonic ST420FF 20" TV
No Color playing DVD just black & White
Have you tried playing the DVD in PAL60,NTSC 3.35 or alternately select the colour system on the TV manually rather than in auto ?
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Codes for tv
usually the universal remote comes with a code book. if you're TV is not on it the remote won't work. But most TV's are on there. If you can't find the TV, go to the ORIGINAL COMPANY of the TV. (RCA, Samsung, etc.)
Jul 03, 2008 | Symphonic ST419E TV
Remotes quit working
Take your Tv to the Technician to check for you if the sensor is working properly.
Mar 24, 2008 | Symphonic ST419E TV
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
Symphonic ST419E TV Logo
683 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
