Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Whirlpool AWO 3361 door lock keeps flashing - Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Awo 9763
Hi Lisa. I'm not familiar with the particular machine but I suspect that if you look just inside the machine near the door catch you will see a small button/lever that operates a switch. (look up microswitches on net). Switch either needs adjusting or replacing. You could try holding the switch closed with your finger or something to see if the machine is going to work - if it does look like working (filling?) the switch just needs adjustment.
Apr 10, 2014 | Whirlpool Washing Machines
Flashing light awo3361
Have you tried unplugging it for 30 mins. then plugging it back in?
Nov 02, 2012 | Whirlpool Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
Whirlpool AWO 10781 door locked light flashing
Hello
Unplug the device from AC mains socket, and replug it after 10 minutes and check. If it does not help you, the machine has to be troubleshooted. Its internal memeory circuit [electronic] has the fault.
Feb 01, 2012 | Whirlpool Washing Machines
Have a whirlpool AWO 3551 washing machine. Door locked light flashes and machine stops at random points in the program. Pump works OK and drains water. Don't suspect door lock module as washer works on...
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
My washing a whirlpool awo 10761 front loader,when i switch it on after 20 seconds the ''door locked'' light starts to flash and the programme goes no further
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
Apr 17, 2010 | Washing Machines
FP fault code on whirlpool washing machine
i have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Nov 07, 2009 | Whirlpool Washing Machines
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
208 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
