Question about Goldstar LG L1004R Window Air Conditioner
Does this need water? - Goldstar LG L1004R Window Air Conditioner
  • 355 Answers
Window unit air conditioners do not need water, in fact the produce condensation that will drip outside the unit, that is why most manufactures say to install your window unit with a little bit of tilt toward the outside portion.
Posted on Jun 06, 2010
Why is my washer constantly filling with water
Hello Friend, this is Z. Thank you for your post!
I see that you are experiencing an issue with your washer continuously filling with water. Here are some basic troubleshooting tips to help resolve this issue:
·Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your washer. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Hope this helps!
Sep 02, 2014 | Frigidaire Washing Machines
Tip
Emergency water supply
When a storm hits or other things go wrong we need water. We can go for two to thee weeks with no food, But at best we can only go three days with out water.Your water heater is a stores 40, 50 60 gallons of water. for a family of 4 that could last you 10 days with some left over. Its your life and family proteect them.
What you need to do. First make sure you have to good working valves on your water heater one on the hot side and one on the cold side. You need to flush out your tank every year. Then let's say a hurricane is heading right for you. All you need to do is close off both the hot and cold water valves. Have a 4 foot section of hose that you cleaned before the storm. Now you need to get water.
Hook up your hose to the drain on the heater, OPEN the relief valve to let air in. Open the drain valve get the water you need and close both valves. Clean water you can drink right away. Save your family fire,shelter,water this first things we need to live
on Sep 10, 2011 | Water Heaters
Electrolux eww1237 error e11
Hello Kidia, I am happy to assist you. Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Aug 17, 2013 | Electrolux Washing Machines
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
Water dispenser is not working
The water flow needs to be checked,if the flow of water is very slow or no water is flowing then water dispenser will not dispense water.But water flow is checked ok then other possibilities like water valve and water line needs to be inspected.For more details.Click the link below:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This should help.Thanks.Helpmech.
Oct 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Only hot water fills the washer...no cold water, even if you put it on cold water only...it then just barely trickles out.
you may need to remove the cold water supply hose and clean out the water valve.There should be a small screen that needs to be removed and cleaned.If that does not change any thing you may need to replace the water valve.
You can also change the hoses around for a quick test of the water valve.
Mar 08, 2011 | Washing Machines
Does this unit need pre heated water?
yes the unit will need to be fed with hot water to work correctly.It has a rise if you want your rinse 180 then you will need to feed the booster with hotter water if fed with cold water it will not keep up under high demand usage.
Jan 16, 2011 | Hatco Compact Electric Booster Water...
Is the pump flow to or away from the watermaker?
In city water or well water system ... the cold water flows from the tank (or meter) toward the hot water heater. The cold water splits in two (so to speak) at the heater with one part going on to the house to supply all cold water needs while the other part goes into the water heater to be heated. On the other side of the hot water heater, there is a system that paralles the cold water system to supply the hot water needs of your home.
I hope this answers your question.
Oct 16, 2009 | Water Heaters
FE code water overfills due to faulty water valve
Water valve is stuck open and needs to be replaced.  The best way to check if the water valve is the problem is to remove the top cover, run the machine to get the water running.  While the water is filling, remove the connector to the water valve that is filling.  If the water continues to run without the connector, the valve needs to be replaced.  If the water stops flowing when disconnected, you may have a control board problem and will need it to be replaced.
Jan 08, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Goldstar LG L1004R Window Air Conditioner Logo
51 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
