Laptop screen is loose
My laptop screen is loose and it wont sit up right without falling apart. Would you be able to adjust the screen so that it doesn't fall apart, and what price range am I looking at to get that fixed?
Thank you
Jessica
my email address is jwales64@yahoo.com
Ebay not avalable on my hinges my model toshiba 2450
Posted on Jul 17, 2008
  • 159 Answers
You may need to get new hinges. try ebay . input your laptop model and space then hinges press enter the results will show availability and price your nearest laptop tech may charge USD20
Posted on Apr 10, 2008
Sharp R-530E microwave door button doesn't open door
I doubt it and a service center will do it right and not cause more issues then most do it yourself people will.
Dec 23, 2012 | Microwave Ovens
I have an Acer Aspire One ZG5. After a minor fall it won't charge anymore unless i push it in the jack with serious pressure. I know the charger isn't causing this as it is brand new and was...
The power jack has a crack solder connection on the motherboard, the only way to fix this you must take the laptop apart in order to address the issue, this task requires someone with high specialty skills to pull it off and be able to use a soldering iron to fix the problem.
Sep 11, 2011 | Acer Computers & Internet
After falling my acer aspire laptop it is working properly but its screen is completely gone white from the right side.please help
Unfortunately the only option you have is to have the LCD screen replaced, they are easily damaged in a fall and there nothing more than can be done. But the video cable from the motherboard to the screen might have been jarred loose and should be checked.
Mar 22, 2011 | Computers & Internet
BB 8900 doesn't work after falling in water
Try talking to someone at www.bbmedic.com They're good.
Dec 20, 2009 | RIM BlackBerry ® 8830 Cellular Phone
My screen went dark suddenly, when I try to restart my computer the screen is tinted red before going dark again. The screen is not completely black as there is letter visible underneath.
From what you are describing, it sounds like the inverter board is failing. This board sits under the LCD screen and is responsible for taking the DC voltage from the battery and AC adapter and converting that voltage to high voltage AC power for the backlight lamp that sits inside the lcd screen. Without that high voltage the screen goes dark. Most inverters do not fail right away, there are voltage fall offs etc. Inverters are approx. 15-20 bucks on ebay, for most laptops, they can be changed out simply by removing the bezel around the screen, unplugging the two connectors on the inverter and changing it out. In most cases except Dell, the inverter is just sitting in there and is not held in by screws.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Apr 14, 2009 | Stairmaster 4600PT Stepper
Manfrotto Tripod head 390RC2 falling apart
I messed with it myself until it finally came apart, found the hidden golt and tightened it, thanks.
Dec 02, 2008 | Photography
Monitor lid will not stay in position.
On most models the hinges are a pressed in, pressure brake type hinges, and when the hinge start getting worn to the point of not holding the screen, then they can only be replaced in order to fix it. You can sometimes get away with replacing just one. On some models there are screws on the hinges that come loose that can cause this. The screws aren't for adjusting, they are basically just set screws. You won't know which is the problem until you take the covers off. Most likely you're going to have to replace the hinges. Try Ebay for the replacements.
Aug 01, 2008 | Acer Aspire 5100 Notebook
Acer 5610 screen problem,ser help
Not too sure about the problem, laptops can be tricky to fix. Sounds to me like it might be a loose connection. Perhaps in the "fall" something was knocked loose?
Unless your an expert at taking laptops apart u might not want to, then again if you can't use it and you think its useless, what have u got to lose?
Mar 23, 2008 | Acer Aspire 5610 Notebook
Computers & Internet Logo
418 people viewed this question
David Payne
David Payne
