Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Microtek C783 Monitor flickers when turned on
Can this monitor be repared...?
    Sergeant:
  • 356 Answers
Hi there. Try to remove and reseat your video card first... maybe there's nothing wrong with it actually...
But if you check the on-screen display, like the brightness controls in your lcd monitor blinking... then you need to have it repaired or replaced.
Hope I gave you an Idea.. ^_^
Posted on Jun 06, 2010
Flickering
hmmmmm ok kindaa easy kinda hard first what are you running because all you need to do is go to stat control panel displays then click advance or what ever to change the hert try change until flickering stop ok hope that helped
Jan 12, 2011 | Microtek C783GM 17" Flat Panel LCD Monitor
I have a Microtek 17 in monitor and recently it has started to flicker badly when switch on after a couple of minutes it settles down to normal. Can you offer any comments re fixing this problem? Many...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 05, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
MICROTEK 19 "C783
19" LCD comes on and goes out right away
Sep 06, 2008 | HP vs19 (Silver) 19" LCD Monitor
Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Jun 20, 2008 | Computers & Internet
MicroTek LCD Monitor
Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor.
May 29, 2008 | Microtek 211SD 21" LCD Monitor
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
228 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
