Question about Samsung DLP HL-P5663W 56" TV
Wiselink won't recognize my WD external hard drive
Wiselink (usb port )won't recognize my WD external hard drive is there anything I can do? I have a samsung dlp.
Your drive is setup as ntfs it needs to be formatted to fat32 via Windows and if Windows won't let you format it to fat32 you need to use a drive partitioner program you can find several free ones on the webz
Posted on May 28, 2016
My WD Elements SE External drive does not have its driver recognized on boot, but does only after repluging its USB 2.0 connection. How do I get the driver recognized on boot? Why does replugging work
I guess it's some kind of a problem with the way your USB port works. I have an external WD too, connected to a USB 3.0 port and definitivly it's not detected at boot, just after windows startup as a USB device.
After some initial wondering about this problem, I decided no to worry more because I use external drive for data backup and if it is not detected by BIOS makes no difference.
It might be a problem of an outdated BIOS or the USB port's driver. In my case, boths, BIOS and USB 3.0 are rather old.
You can do some reading about issue if you do a ggogle search for issue
USB 3 0 external Hard Drive not detected after Intel Communities
External USB 3 0 HDD is not detected in Windows after boot Help
Aug 06, 2015 | DMCOM Western Digital Wd Elements Se 1 Tb...
My usb ports on my laptop only recognizes my phone and mp3 player and not my external hdd, it tells me to format the plug and play external hdd. It does not do this in all my usb ports though
Maybe the external hard drive is to large to be recognized by your computer. Some computers won't recognize real large external drives.
Another problem could be that your external hard drive does not support Windows 7.
May 20, 2012 | Acer Computers & Internet
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
The WD hard disk 160GB is not recognized after plugging into USB
It is very possible that your BIOS will not support a large hard drive. Without more information on your system it will be hard to diagnose your problem.
Oct 06, 2009 | Western Digital Elements powered by WD 320...
WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Sep 15, 2009 | Western Digital Elements powered by WD 320...
My mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 31, 2009 | Western Digital My Book Essential 500GB...
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Samsung DLP HL-P5663W 56" TV Logo
527 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
