Question about JVC Televison & Video
Have a 1995 JCV flat panel TV, model#C13WL6 I can't scroll up or down the channels; it is stuck on ch 2. I can enter limited channel nbrs to go to the channel; and I don't know how to register the channels so the TV will be able to scroll up and down using the up and down keys. Thank you, Rod email - rlramsey1@yahoo.com
    President:
  • 1,961 Answers
Good day sir,there is just 1 channel programmed to the memory of your tv thats why your not able to scroll up and down.You need to program all the channels there is a manual programming and auto program.to do it,On your remote control press menu and select channel searchand choose auto program and the tv now will scan all the available channels and save it to the memory...thank you have a good day
please rate my help tnx.
Posted on Jun 06, 2010
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
How to delete ch. on my 32c11ou tv so I don't have to go thru all the ch.
What you want to do is skip the channel when using to channel up and down buttons on the remote from what I understand. What you do is press menu on the remote to open up the setup menu. Use the arrow keys to navigate. From there highlight "Installation" and press "enter". Select "Channel Options" and press "enter" and the list of channels will be displayed. Scroll through the list and find the channel you to want to see and press "enter" a check mark will appear. If you make a mistake just hit "enter" again to remove it.
Jul 16, 2011 | Televison & Video
How do you activate the tv to scann for channels?
Use the tv remote push the menu button go to SETUP,than go down to Ch.pick AIR or CABLE than enter for scranning for channels for pay CABLE or free AIR channels.
Mar 02, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
People faces and a lot of other items on the screen are not natural looking, kind of like a manaquin. Stripes are distorted. It is brand new and I was wondering if the problem is the tv or something else....
On this television you would need to remove the Comcast digital cable box. This tv does not need it. Then you will press the menu button and choose either the channel or the setup category. You will then need to locate the auto ch memory or ch setup subcategory. Then you will select it by pressing enter after scroling down to it. Next you will scroll down to automatic search or ch search and press enter. Select search start for just digital channels and press enter. It may direct you to select yes and then enter. After the television is done searching the 135 channels it will come back to channel 2.1 or the lowest channel you receive. You can then go through your channels with the ch button on your Sharp remote control. The picture can further be adjusted with the av mode button on your remote if you press it repeatedly if you remote control has one.
Apr 17, 2010 | Sharp 19 in. LCD HDTV
Channel Search
With remote, hit MENU, (use up/down arrows) & scroll to SETUP. Hit ENTER & scroll to TV. Hit ENTER & scroll to AUTO CHANNEL SEARCH. Hit ENTER & scroll to CABLE. Hit ENTER & scroll to AUTO. Hit ENTER, wait as it scans (about 5 min). Your done.
Jun 18, 2009 | Televison & Video
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Programming channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
