Question about Waterway Spa Pump Executive 56 Frame 2hp Single Speed 2 1/2" Intake 2" Discharge
Need a wiring diagram for the pump as it was frozen and I removed from the housing.
    Genius:
  • 1,040 Answers
Dear Pgegen,
Visit to the following link for your solution.......
http://www.spadepot.com/spacyclopedia/pumps.htm
Posted on Jun 06, 2010
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Diagram of installation process alternator 1998 Volvo S70
I don't have a diagram. Here are the steps.
1) disconnect negative battery wire..
2) remove serpentine belt
3) remove upper heater hose and thermostat housing; leave thermostat in place
4) remove plate from in front of the power steering pump, the lower bolt is one of three of the alternator bolts.
5) remove all 5 bolts from the PS pump bracket - 2 are by the thermostat housing. Remove the bracket.
6) move the PS pump off to the side out of your way.
7) Remove the long bolt from the alternator you can now see. There is one more alternator bolt at the top which will allow you to remove the idler pulley bracket with the serpentine tensioner. This idler bracket and the tensioner bracket are sizeable, so you have to understand the volume of stuff you are removing.
8) Unhook the alternator wire and with some patience, if you have any left, you can squeeze the alternator out.
This procedure assumes you have the ability to do the serpentine belt removal and refitting, and you will need 12mm sockets/wrenches to do the rest. The t-stat housing uses the torx head screws, so you need that as well.
Mar 02, 2015 | 1998 Volvo S70
Remove fuel lines from fuel pump housing
You may need a fuel line tool that compresses a spring in the collar. You can get them at any auto store..
Apr 28, 2013 | Cars & Trucks
Wiring the circuit board i need a diagram
wiring diagram for what brand? is the circuit board located in the pump housing or in a separate box?
Rod
US Parts Center
We locate the "seemingly" impossible...
888-521-6183
Jan 20, 2013 | Home
Have a rule 1800 Pump and my dog ate the cord
so cut repair and tape and fix if its near water side use silicon make sure dosent hit water
Jul 22, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
Engine diagram 1997 buick skylark/thermostat
follow the water inlet pipe to water pump the thermostat housing connects to water pump this is for 2.4l engine you have to remove exhaust manifold heat shield.you will see the water inlet pipe going to water pump inlet thermostat housing.for the 3.1 engine follow top radiator hose to thermostat housing you have to remove air filter air duct and filter housing , you have to remove throttle body unit with coolant hoses, you have to disconnect accelerator cable, transmission down shift cables at the bracket bolts to throttle body.once you remove throttle body unit then you can see and remove the thermostat housing to replace thermostat.you need to buy new throttle body gasket,and new small coolant hoses connects to the throttle body unit.have extra gallon antifreeze dexcool on hand.
Nov 15, 2011 | Cars & Trucks
I need to replace the fuel pump and the parts house sells it with wiring. Do you have a diagram of how to run the wiring?? It is for a 2000 chevy blazer. Need it asap.
Grey is the power to the fuel pump.
Purple is the power to the fuel level sensor.
One black wire should go to the frame (fuel pump ground).
The other black wire should go to a connector and back to the fuel guage.
Mar 16, 2011 | Chevrolet Blazer Cars & Trucks
WASHING MACHINE SPIN CYCLES NOT WORKING
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
The following is a link to a diagram of washer parts, If you scroll down about half way down the page, you will see the pump:
washer water pump
Jan 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
May 12, 2009 | Heating & Cooling
How to change an o-ring above oil filter and above oil cooler.
remove the hoses from the top side of the engine first its a lot easier, then replace the seals on the cooler, its not a nice job even on a ramp
Dec 09, 2008 | 1994 Volkswagen Passat
Waterway Spa Pump Executive 56 Frame 2hp Single Speed 2 1/2" Intake 2" Discharge  Logo
75 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
