My webcam opener thing on the side of the screen and it is highly obnoxious, it hinders me from watching full screen videos, as well as accessing some of the programs on my desktop, for it is in the way.
You can disable the webcam software from automatic loading.
In RUN type msconfig and start this tool. There you will see the tab called “Startup”. Go to this tab and disable the webcam software (remove the mark). Then apply the changes and reboot the notebook.
Now the Windows should boot up without the webcam software.
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be
used not only for playing games but also for watching high-definition
movies. The best way to connect a PS3 to a high-definition viewing
device such as a video projector is through the PS3's high-definition
multimedia interface (HDMI) output. The HDMI connection can transmit up
to 1080p high-definition from the PS3 to the video projector using a
single cable. Attaching and setting up the HDMI cable will only take a
few minutes and will let you watch high-definition video from the PS3 on
the video projector.
Connecting HDMI
Attach one end of the HDMI cable
to the HDMI output connector of the PS3. Turn the HDMI cable around if
it does not slip right into the HDMI output, because the HDMI cable can
only fit into an HDMI connector one way.
Attach the other end of the HDMI cable to the HDMI input connector
that is on the video projector. Make sure both sides of the HDMI cable
is securely pushed into the connectors of the PS3 and of the video
projector. Turn on the video projector. Press the "Menu" button on the
video projector's remote. Navigate to the "Sources" setting on the video
projector's Menu. Select "HDMI" from the "Sources" setting. Press the
"Menu" button on the remote control again to exit the Menu.
Adjusting the PS3
Turn on the PS3. Wait for the
"Home" menu to appear on the video projector, although the quality of
the video seen from the video projector will be muddied and dark.
Navigate from the "Home" menu to the "Systems" icon using the game
controller and select the "Display Settings" tab. Choose "Video Output
Settings" from the list presented in the screen that appears. Press the
right side of the directional pad on the game controller to move to the
next screen.
Choose "HDMI" from the list presented in the screen that appears.
Press the right side of the directional pad on the game controller to
move to the next screen. Choose "Automatic" from the list presented in
the screen that appears. Press the right side of the directional pad on
the game controller to move to the "Confirmation" screen. Press the "X"
button on the game controller to make the settings active. Return to the
PS3's "Home" menu.
Watching the PS3
Insert a Blu-ray disc into the
slot at the front of the PS3. Wait as the Blu-ray disc begins to play
the video content on the video projector from the PS3 through the HDMI
cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
<p>There
are two prevalent formats for video programming: full screen and wide
screen. LCD TVs are designed to show a wide screen picture to go with
high-definition (HD) programming. When standard-definition (SD)
programming is watched on an LCD HDTV in its default settings mode,
there will be two vertical lines on the right and left sides of the
picture. You need to go into your TV settings menu to troubleshoot this
issue.<br />
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
<span><br /></span>
<span>Instructions</span>
<ol>
<li>
Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br />
</li>
<li>
Select "View" from the list of options.<br />
</li>
<li>
Choose
a viewing mode that will eliminate the vertical lines. Select "Zoom" to
crop the on-screen image to fit the screen. Select "Wide/Widescreen" to
stretch the on-screen image to fit the screen, or select
"Panoramic/Panorama" to stretch the sides of the onscreen image to fit
the screen (recommended).<br />
</li></ol>
It is most likely the fan. When doing things like watching flash video (e.g. YouTube or Hulu), it uses a lot of CPU power, thus your fan needs to spin in order to keep your computer from overheating.
install an AGP card in the AGP slot (accelerated graphics port) then you can see high resolution also you can play '3D games 'and look 'HD video' but internal display card of the 'motherboard 'does not support the high resolution because of the insufficient memory . use ' 8X AGP card' for the better result .
• Open Windows Sidebar by clicking the Start button , clicking All Programs, clicking Accessories, and then clicking Windows Sidebar. To keep Sidebar visible at all times, you must set it so that other windows won't cover it. The Sidebar width is a fixed size.
To keep windows from covering Sidebar
Because of the space Sidebar requires, this option works best if you're using a large or wide-screen monitor or multiple monitors. 1. Open Windows Sidebar properties by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Windows Sidebar Properties. 2. Select the Sidebar is always on top of other windows check box. 3. Click OK.
Look up "Windows Sidebar Properties" in the Control Panel (classic view) and turn on the sidebar to start with windows, and always on top. Check the other properties to make sure they are doing what you want.
Don't quite know what you mean by "enlarging an object on a website", and do you mean it's now showing as the screen saver image? If so, you can go into Control Panel, Personalization, Screen Saver - and select a different screen saver, or "(none)"; or if the image is actually on the Desktop, the settings for that are also off the Personalization window.
Lots of other useful things in Control Panel, might be worth spending a little time getting to know what's there?
Okay go to start and open the control panel. Click on the appearance and personalization link, Click on windows sidebar properties and select start sidebar when windows starts. Then log off then log back in, and you should have your sidebar again.
Hope this helps, Ryan Frame Creative Energy Associates Technical Center
