Question about Microsoft Likom HD19A 19" LCD Monitor
Power plug what kind of plug does the likom hd 19a takes
  • Microsoft Master
  • 32,281 Answers
Most LCD monitors use IEC sockets - these are 3pins sockets.
Power leads are available from computer shops and electrical stores.
Posted on Jun 06, 2010
Likom lcd autonatic shutdown
Sounds like a hardware issue. Make sure your settings on your computer are not causing it.
If its not your settings then it is a hardware issue with the monitor which sadly means you will have to send it to the manufacture or someone who does hardware repair.
Jul 22, 2011 | Likom HD15A 15" LCD Monitor
I need to know if my lcd monitor Likom HD15A you can change the resolution d epantalla over 1024, I have SO please confirm W7
No, that is the native resolution of your LCD Monitor, it can not display a higher resolution.
Apr 12, 2011 | Likom HD15A 15" LCD Monitor
Even when laptop is plugged into an electrical outlet, it will suddenly think it is not and drain the battery power..the indicator lights will flash and battery power will drain.
There may be a fault in the laptop's power supply adapter.
Try testing its rated output voltage versus the actual with a multimeter.
If the adapter comes in 2 sections, 1 cord from the wall to the adapter, and then the adapter to the laptop, be sure to test both sections.
Replace the adapter if required.
Also check that the connection socket where the power adapter plugs into the laptop is not loose and preventing proper electrical contact.
Good luck.
Feb 28, 2011 | 4D NSpire Power Supply NSP-300P4D 300W...
I NEED THE SERVICE MANUAL FOR AN AG NEOVO E-19A MONITOR.
Good luck on that one...you can only get that if your a service center.
Dec 11, 2009 | Neovo E-19A 19" LCD Monitor
Neovo e-19a flat panel will not work with gateway e4000.
You may have to turn on the external video from inside the BIOS; not all systems are set up to feed video to the VGA port unless told to do so.
Oct 26, 2008 | Neovo E-19A 19" LCD Monitor
Blackouts
have you checked your ram
Apr 03, 2008 | Neovo E-19A 19" LCD Monitor
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Likom HD17A blacks out
Just check that your monitor is not set to power down(Control Panel> Power Options) and check that the 'Turn Monitor Off' Power Scheme is set to never and turn off any screensaver to see if it still goes off.
Oct 24, 2006 | Likom HD15A 15" LCD Monitor
Microsoft Likom HD19A 19" LCD Monitor Logo
95 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
