Question about Vacuums
ELECTROLUX OLYMPIA ONE HOSE
HI,I'VE REPLACE THE OLD HOSE WITH A NEW ONE. I'M USING THE ORIGINAL HANDLE. I WANT TO USE THE VINYL SHEATH THAT'S JUST BEHIND THE HANDLE ELECTROLUX NO LONGER USES. OBVIOUSLY WHEN ELECTROLUX MANUFACTURED THE HOSE THEY PUT IT ON BEFORE STAMPING THE METAL/PLASTIC ENDS ON. ANY IDEAS? CAN I REMOVE ONE OF THE ENDS WITHOUT COMPROMISING THE INTEGRITY OF THE HOSE?
    President:
  • 1,673 Answers
Usually the older hose get replaced, they just weren't made to be repaired, if it looks like something that will come off, then try either warming the sleeve up with hot water or a hair drier to see if you can work it off after it has warmed up.
Posted on Apr 26, 2008
Electrolux power head not working no power
There are four points of connection to get power to the nozzle, any one of which can cause this condition, or an on/off condition. They are the connections in the neck of the machine itself where the hose is inserted in front. The second is underneath the hose handle, where it connects to the two pronged sheath cord. The third is at the lower end of the sheath cord where the power nozzle cord connects. The last is the reset itself. That's what I check first when one of them is brought into my shop, because, believe it or not, most people don't know that there's even a reset there. If the little red button is sticking up push it down firmly but not hard. It's possible to push the bottom right out of the reset unit itself. If the nozzle doesn't activate after pressing the reset, start by disconnecting the power cord that goes to the wands. Check for blackened, enlarged connection openings, or charged, blackened prongs. If no problems found there, continue on up the handle checking each connection point for these conditions. If you find the problem at any of the connection points both parts must be replaced, the male and the female ends. That usually means replacing the cords themselves, as the ends are not available separately. If the power nozzle still refuses to run you or a qualified repair person will need to open it up to check the motor itself to see if it's any good. Once the faulty part,(s) are found and replaced it should start right back up and run normally.
Jun 15, 2014 | Electrolux Vacuums
Repairing contacts in Electrolux Z8240 handle
Hi There, Alec From VacuumSpot here. I work as a vacuum technician and unfortunately I am the bearer of bad news the handle is not really repairable. Even in warranty Electrolux allowed us to simply swap the hose over in favour of any repair. If you need to buy a new Z8240 hose the part number is 1131404541.
Nov 27, 2012 | Electrolux Vacuums
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
Hello, I have a Hoover quadraflex Powermatic central vacuum system Model # s8099-031 that requires a new replacement 35 ft hose...I have contacted Hoover and they do not know where to buy a replacement...
Tammy, no info re your location, so I''l try this.
Your Hoover hose is shot because it was made of rubber.There are new swivel handled, tangle proof lighter hoses made of vinyl which will last much longer and can be adapted to the old Hoover head by changing the upper steel tube.
Find a Hoover service center, outlet in the yellow pages and ask for the "NEW "style, gray``Plastiflex`` brand hose and upper adapter tube sold with new Hoovers at Costco and you will be all set. Then, when the head eventually dies, you can upgrade to a far better one , while still having the Hoover cannister, the hose and tools do not need to match the original tank.
Sep 17, 2009 | Vacuums
Remove hose from handle on old electrolux canister
BE careful here. Do not fish a coat hanger in the handle.
The original hose has a set of detachable handle componnets.There are two metal screws in the underside of the hand grip.Do Not pry. Once removed go to the suction dial area underside of the grip. Observe the plastic fingers near the dial. These must be reset in their " track " when reassembling the handle.
Gently insert a small flat screwdriver between the rubber wiring contacts and the plastic tongue wraps around the socket. this tongue which extends from the hose handle adjacent to the metal tube. Work you way back to the hose area carefully separating the "hand grip cover" from the hose handle itself.
Once apart remove the obstruction. Carefully clean the two brass rings looking for any pitting. If pitted, gently polish by rotating fine wet/dry sandpaper around the rings, then lube with vaseline.
The matching contact fingers on the handgrip cover should be cleaned as well and gently tensioned to put a bit more presusre on the contact rings.
Slide the handle ONLY onto the hose. Once in place the contact rings will be visible. Now you can work the handgrip cover back into place starting with the two tabs at the hose end below the contact rings. To seat the small fingers at the control valve gently click into place before reinstalling upper handle screws.
Jun 15, 2009 | Electrolux Central Vacuum
How to replace sheath cord on eletroux
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=840565
Generic problem for all Vacuums
Posted by ellie_pesca on Jul 27, 2008
How to replace sheath cord on Electrolux
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Just bring in a sample of the Electrolux sheath cord to your local vacuum cleaner dealer in your area and chances are he will have the part to replace the sheath cord for the Electrolux. Or you can contact the Electrolux factory website or the cust serv line and supply them with the brand name and model # of the vacuum and they can either send it out to you or let you know where you can get one. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 27, 2008 | Vacuums
My electrolux vac does not **** up dust despite anew container and no obvious clogs
TAKE OFF THE HOSE AND PUT YOUR HAND OVER THE OPENING. IF THE SUCTION IS STRONG YOU NEED A NEW HOSE. I JUST REPLACED THE HOSE ON MY 28 YR. OLD OLYMPIA ONE AND THE SUCTION IS AS IF IT WERE BRAND NEW.
Apr 15, 2008 | Vacuums
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Nov 08, 2007 | Electrolux Centralux Vacuum
Vacuums Logo
220 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
