Question about Samsung CLX 3160fn All-In-One Printer
How do I replace the imaging unit??? - Samsung CLX 3160fn All-In-One Printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Hello ...You have 2 take out the toners.Then you will see 2 screws ..take the waste toner botle out and the the screws.take of the cover ,on the right hand side is a conector plug unplug it .puch down on the black lever in the midle of the unit at the bottom and pull the hole drum unit out.The transfer belt is till in the machine, if you whant to take that out also you will see there is sort of a handle on the left side that you have to pull an that will also come out easily.
Posted on Jun 09, 2010
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
C-2253 erroe code
DID Some one recently replace a color image unit? Was that image unit stored standing up? and placed directly into the machine.? Might have all the developer sitting at one end and motor can not turn. Pull out all the image units, shake each one along the axis of the unit to spread the developer over the entire length of each image unit, then re-install, open close front door to reset code, if the code comes back you might have a burn out color image motor, or on of the color image unit needs to be replaced replace all three, worse case the board that controls the motor was damaged. Store all Image units and toner length wise
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 30, 2015 | Konica Minolta Minolta Bizhub C253 Copier
I get a loud noise from the drive unit of bizhub C35, and the machine comes up with an error message to install Black IU. I had replaced the black IU twice now and also had replaced the whole drive...
First using alcohol clean the electronic chips under the image unit. and the contacts on the printer. Also shake the image unit side ways to ensure all of the developer and toner are spread along the whole body of the image unit. DO NOT STORE IMAGE UNITS UP AND DOWN!. DO all the image units. Might have a bad image trans belt and or fuser unit.
Feb 20, 2015 | Konica Minolta bizhub Office Equipment &...
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
Need to replace imaging unit . konica c252
http://www.precisionroller.com/imaging-units-for-konica-minolta-bizhub-c252/products.html
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Jan 07, 2015 | Konica Minolta BizHub C252
Error code C0F32
This error means Imaging Unit ATDC (automatic toner density control) failure. Open and close the right side door where the imaging unit is. If the code comes back you are going to need Imaging Unit service or possible Imaging Unit replacement. The best option and the cheapest is to locate a new imaging unit and replace it yourself. These units are very easy to change and similar to replaceing a toner cartridge in any laser printer. Just do a search for Di200 Imaging Unit.
Good Luck and Thank You for using Fixya.
Apr 14, 2010 | Konica Minolta DiALTA Di200 Copier
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Mar 02, 2009 | Konica Minolta bizhub C450P Laser Printer
Resetting the imaging unit
How do you reset the imaging unit?
Dec 19, 2007 | Samsung CLP-510 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
152 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
