Question about Nintendo Wii Console
I put the remotes on the charger and they are green but i cant get the remotes to do anything
    Problem Solver:
  • 15 Answers
Hmmmm do they connect to your wii or not.. if they do then try and nothing happens then either your wii isnt picking up the command or the remotes buttons are messed up.. you probably have to replace the remotes or the wii ... if you have warranty go to the place you bought it and ask for it to be repaired
Posted on Jun 06, 2010
I've just brought a new e300 from Argos and put it on charge tonight and checked it after 10mins and the green light is on the charger is this normal?
Green is usually good. Beware of red lights. 10 minutes is too short to charge anything. On a new item, try 12 hours.
May 10, 2015 | Toys
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
I cant get a picture on my tv. DM Tech LM37xty
Either bad main logic board or bad lcd panel. If bad panel, it's not worth repair. Can find main board at Encompas Parts.
Nov 16, 2011 | Televison & Video
When i put the battery in the charger the light blinks. how do you know when the battery is charged???
the light will change to a constant green when fully charged. Anything other than that and you might have another problem. It usually takes about 1 hour
Aug 03, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
Hi, My Makita DC18RA won't charge anything it just flashers the red and green light simultaneously it is not the batteries because I can charge them fine using anther charger. What is wrong with the...
none of these answers help. you cant return old chargers to the store, and the poster said his battery charged on a different charger. i have the same problem with 2 makita battery chargers and need to know if there is a part inside the charger that can be replaced.
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Im losing channels on my tv. because i cant do a channel search
It's only thru your remote. try fixing your remote control.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Feb 23, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
My charger for my env2 will not fit in the hole thing and wont charge. I cant figure anything out and i need to charge my phone ASAP please Help!!!
I think you should go to the Verizon store and tell them about your problem. But if you've only tried putting the charger in one way, try flipping the charger over and then putting it in or put the charger in a different spot on the phone. Search until you find the right one!
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
Battery Not Charging
I had this same problem and searched on the web for answers.... I could not find an answer; just complaints. I tried something that solved the problem! I noticed a greenish buildup on one of the three metal contacts on the battery. I wiped the green stuff off then the battery charged as normal.
The problem I was having (to ensure we have the same problem) was that the wii indicated the battery was out of power. I would put the remote in the charger and the indicator light would turn blue to show it was charging. A few seconds later the light would turn green to indicate it was done charging and was full. However, the battery was still empty. This would occur even if I left the remote in the charge overnight.
With the fix I listed above, the batteries now work as normal!
Aug 20, 2008 | Nyko Charge Station for Nintendo Wii
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Nintendo Wii Console Logo
108 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
