Question about Poulan 18" Wild Thing Chainsaw
Hard starting,but when started runs good,then put it down on ground it shuts off,always ran good before just recently had this problem.
    Problem Solver:
  • 8 Answers
The choke isnt rattling its way back to cold start position is it? Had the same problem but with my backpack blower. Keep an eye on the choke while its on the ground. Also, check the priming pump, that little button you push to prime it, make sure there isnt a leak coming from there.
Posted on Jun 06, 2010
Can't start my 2008 yamaha 540 was cold that day ran out gas put gas. Didn't start
Try lots of gas line antifreeze and change the fuel filter. Spark plugs should be dry, you may have plugged filter or water in the gas or both
Jan 28, 2015 | Yamaha 2005 VK 540 III Base
1996 GMC JIMMY, Hard starting after it has ran for awhile
could have a battery ground , check cables for corrosion.
could also be the starter or the solenoid.
you could also have a dead short in the battery itself, it will be ok if it sits but will give you fits for repeated starts
Apr 16, 2013 | Cars & Trucks
1991 chevy c1500 stalling
Usually a problem with a dirty throttle body or a faulty idle air control valve. The computer controls idle speed by regulating how much air enters the intake thru the valve.
Oct 13, 2012 | 1991 Chevrolet C1500
1987 corvette with 26000 mile always garage kept from birth. Start once a week always starts inless than half a crank. But after ran down road for while and shut off takes 5-7 revolutions to fire. Almost...
Thee new fuels today go bad after around 3 weeks because of the ethonol content. Put a can of Sea Foam in the gas tank see if that helps clean it out. Best bet is to drain the tank put new fuel in it with a can of Sea Foam, then give it a good long run until the tank is empty. Re fill the tank and put the correct amount of Stabil in the with the gas, this will stop the gas from turning into sugar and it works for years.
Good luck
Jul 09, 2010 | Cars & Trucks
I have a 1995 Saturn SL1. It was running on 3
Have you resistance checked the injectors. If the resistance is wrong the pcm will shut the injector drivers down.
Mar 31, 2010 | 1995 Saturn Sl
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
2002 trailblazer lack of engine power light
I am willing to bet a lot that there is a bad ground from the battery to the chassis of the vehicle. In addition to the ground wire that goes to the engine block, there should be another wire from the battery negative terminal to the sheet metal of the car. Bet is it corroded or loose. If you cannot find this wire it might be because the MFG ran a wire from the engine to the sheet metal somewhere around the back of the engine. You can run another wire frokm the Batt- term to the sheet metal. Maybe put one terminal under some accessory that screws to the sheet metal.
Good luck
Feb 07, 2009 | 2002 Chevrolet TrailBlazer
Poulan 18" Wild Thing Chainsaw Logo
128 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
