Question about Maytag EPIC MFW9700S Front Load Washer
F35 maytag front loader washer error F35
geemarie
  • 876 Answers
SOURCE: Whirlpool Front Loader Washer Model# WFW9600
This code is not on the list.
Try this:
Push cancel twice
Select drain and spin
Select your cycle and push start.
If this does not clear the code, you will need a service call.
Before you do that I am wondering-Are you using an HE detergent and in small amounts? Are you loading the washer evenly- for example towels with towels lingerie with lingerie and jeans with jeans. Front loaders are very sensitive to how they are loaded. Check everything you can:
Turn off the washer and unplug it. Grab some old towels and a bucket.
Check the drain hose- is it twisted, squished or plugged ( you can turn off the washer unplug it and remove the drain hose to see if it is clogged.) While you are back there check the incoming water hoses are they twisted? Unscrew them from the washer and make sure the little filters at the ends of the hoses are not plugged, so that water is coming in freely. Make sure water valves are turned all the way on.
When you are back in front examine the door seal. Is it in good condition? Give the tub a spin with your hand. Does it spin freely and does it feel secure?
Check your dispensers. Are they clean and empty? if they are not try running an empty short cycle with just a little Hot water in the liquid dispensers to see if they are plugged.
Okay. Good luck to you. I hope this can be solved without a service call.
thank YOu for using FixYA Ratings are always appreciated.
Posted on Aug 24, 2008
SOURCE: Control Locked
this is a child safety lock feature to keep them from turning on and off the machine, you must hold down the cycle end button for 3 seconds to unlock the machine, you will find these instructions labeled right on the machine and in your owners manual.
Posted on Nov 01, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 744 Answers
SOURCE: my front load washer displays an f28 error code
See the FixYa post:
http://www.fixya.com/support/t800390-f28_error
Posted on Mar 29, 2009
F35 on maytag 5000 series front loader.
A F35 error indicates the Central Control Unit has detected a malfunction of the analog pressure sensor.
Oct 11, 2014 | Maytag Washing Machines
Code f35 and sud on washer machine/whirlpool duet front loader
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
F35
f35 and sud replace your pressure switch
Jul 02, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool front loader
I've had this same problem and had a service man come in. The reason for the colde is an over-gunked up machine due to the directions for amount of soap to use on he bottles being incorrect.
Run the washer empty several timres with just vinegar in place of the soap and then repeat with bleach. I've been told this will take care of the problem, but it may take many cycles before the codes will stop appearing.
Also, from then on, only use 3 tablespoons, yes 3 tablespoons or 1 ounce of detergent per wash. The 1/4 cup that most he detergent bottles tell us to use is way too much.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
