Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd-52525 I have a 2004 Mitsu wd-52525. For about 1 year the tv has been pretty dim, only looks good in a dark room. The green timer light also occasionally flashes very fast and I have to unplug the set to get it to work again. After I turn it on after unpluging it, it asks if I replaced bulb. Yesterday the set stoped showing the picture. It goes to a blue screen on all video settings and has a white flashing light in the center with Horizontal lines moving from the center to the edges. Suggestions Please. Thanks Richard
  • Mitsubishi Master
  • 8,617 Answers
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Posted on Apr 10, 2008
  • only darknes Feb 23, 2011
    HEY Guru
    what do you know about a 57" Mitsubishi DLP the pictture has been dark, we can watch it but it is dark. mODEL # wd57731
    thank you
    arick k
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
Practical soln. for the blinking green light?
Call Encompass Parts or visit their website online 1-800-638-3328 and FOX has Lamps for $109.00 1-800-227-5369 Heres you another Tip Go to E-Bay they have alot of Good deals there Look under Electronics
Dec 08, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62327 Screen is very dim
I tooked the front screen off the TV set. I fallowed the instructions from another wrighter. The Bottom mirror was clouded with dust. I used a cleaner made for cleaning ipods and put it back together with instant success. I had not cleaned it since I got it almost four years ago. I just thought it was getting dim.
As far as the VCR playing black and white it also an easy fix. The Satalite Service man was swapping out my receiver and inadvertaly put the device on componite side of the TV. I put them back on Inpute 1 and 2 and they also work just fine. Thank you for your help.
reading other people porblems I was able to repair it on my own.
Dec 26, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
175 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
