Question about Samsung Washing Machines
Samsung washer p801 fault code EA. E flashing and A solid on. What does this mean and how to solve the problem. tks
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: samsung washer p801 1 year old need shaft on back
Repairclinic.com. They have the parts for your machine. You can even call them and they will assist you
Posted on Feb 18, 2009
SOURCE: Samsung washer P801 sticks/stops while
Hello Folks
When your front load washer starts to shake violently it is usually because the 2 shock absorbers are done.
Parts cost about $10 each. You need to take the top off the machine and the front. The bottom bolts are accessable from the front. The top bolts are harder to get at and a helper is very usefull.
Put a little blue lock tight on the bolt threads when reinstalling them.
Cheers
Bri
Posted on Apr 04, 2009
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
I have A samsung washer p801 and the washer wont close it keeps telling me Ed and i tried turning off the machine and closing the door and turning off the machine when i open it but the door just wont lock...
ED is a door not closed error code. The lock may be on and the machine will need to be reset. To do this either leave the machine unplugged for 24 hours or see if there is a reset option on the machine. If you need an owners manual, I can probably locate one for you .
Jun 05, 2012 | Samsung Washing Machines
Washer fault code 3E what does it mean
during washing and rinsing when a motor restriction is sensed, the motor stops and then proceeds
to the next waterflow action. if the motor stops working and this happens in one direction 10 times,
the error code 3e will be displayed.you should be able to clear the error code by turning your washer
off and on. or powering it down and then powering it back up. good luck!
Feb 21, 2011 | Samsung Washing Machines
We have a WFW8300 Duet Sport. the code is F-..what does this mean.
F-11 Codes and Vibration:
F11 fault is actually described in the tech sheet as a "Serial Communication Fault" involving the MCU (the washers computer) and the DC Drive assembly that runs the motor. If you are not familiar with a DC drive, it is simply a controller for the motor that varies the voltage to the motor to change speeds.My research showed many people solving this problem with a replacement of the control unit or the relays inside of it.
The problem with the engineering and design of these washing machines was that they all vibrate excesssively unless they are sitting on a floor constructed of a ton or more of solid concrete.
The vibration eventually makes either the motor serial/tach connector (or possibly one of the five relays in the control unit) intermittent, and the machine begins to throw error codes
I have found a good whack on the side of the machine seems to work. No kidding. Here's what happens: Stupid F11 flashes. I hit the pause/cancel button. It flashes the remaining time on the cycle. I hit the start button. Sometimes that just does it. If it doesn't I give it a whack on the left side of the machine, (if you're facing it), in the middle, about 6 to 8 inches above where the drawer is.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine does not finish complete cycle
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Jul 06, 2009 | Samsung WF203ANW Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
298 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
