Question about Flip Video Cameras
Screen shakes then goes either to the left oe right then goes out
  • rlg561 Jun 06, 2010
    thanks for the sound advice
  • 12,061 Answers
I have seen this before and similar a couple of times from what I can gather it is something to do with prom damage and it software glitches and shuts the screen off. What you see is the screen shut down sequence, and depending on what side of the register it is is the way it goes when it shuts down, that's what "Gives it away", when fault finding.I have had success with a Factory Reset, (You may like to try that) on one or two, the others were "Hard" faults, and when it comes to an internal work, it really does have to be returned to an authorised service center, as they are the only ones with the, rooms, tools and data on the instruments. However they ended up being Non-economic repair, meaning it was going to cost almost as much, if not more than a new comparable one.. You really need to get your service manual and your user manual, Google for both, just use the exact make and model and the words service manual in the Google search bar.
Posted on Jun 06, 2010
I have Toyota 2006 sienna and front right wheel shakes or wobbles ... I have new front tires and balanced.. but still wobbles a little...please any thoughts?
Hi Scott.
Try switching the wheels from left to right side and see if the wobble goes with it.
If not, look for a worn tie rod end or other suspension component.
If wobble goes to left side, look for bent rim.
Cheers.
Oct 10, 2015 | 2006 Toyota Sienna
94 eagle summit vibrates left to right at speeds in excess of 50mph. the steering wheel does NOT shake with the vibration. It only vibrates after driving for 40mins+.. It comes and goes, not constant. ANY...
Left to right wandering that starts after 40+ minutes means that the effect happens once something gets hot.
I'd suspect first tires or suspension (tie rods or ball joints). Could be a jamming inner CV joint, but this generally results in steering wheel shake too.
Might also be an engine misfire. Check wires, plugs and injectors.
Could also be fuel starvation on a low gas tank. Check the evaporative system.
Dec 02, 2010 | 1993 Eagle Summit
At low speeds the steering wheel goes left and right by itself. At highway speeds it viabrates
If it's shaking left and right and shakes faster the faster you go i wood say it's slipped belts in the front tires.Hope this helps.
Feb 25, 2010 | 2001 Chrysler Town & Country
I have an LG steam washer less than a year old. The machine has an error light OE which is a drain error. I have unplugged it and tried to restart it but it does nothing. Any ideas what I need to do...
The door on the bottom left of the machine, open it, and disconnect and drain the hose that is in there. Get a bucket handy there will be a lot of water. Try that.
Jun 13, 2009 | LG WM2688HWM TROMM SteamWasher
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
My lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error Code "OE"
sounds like your machine needs rebalancing..check the feet and floor to ensure it's level and balanced
Apr 25, 2008 | Washing Machines
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Oct 17, 2007 | Toshiba 36AF43 36" TV
Screen side right and left shake
How often does this happen? How long does it do this for? After it happens, does it look normal again? It sounds like your monitor is automatically "degaussing" (de-gowse-ing) -- this is a process which reduces built-up magnetic fields on the monitor which can affect how it looks over time. Usually, you'll hear a noise when it does it, and at the end of the process, usually a distinct "click" when it snaps back to regular operation. Some monitors do this automatically when they are turned on, and some can be made to do it manually. I've not seen one that just does it at random times though.
Apr 04, 2007 | Taxan Ergovision 735 TCO 99 17" CRT...
Cameras Logo
16 people viewed this question
Top Flip Video Cameras Experts
Are you a Flip Video Camera Expert? Answer questions, earn points and help others
