Question about Samsung AW0503B Air Conditioner
1.5 ton ac. It is getting cold near the outlet but cold air is not blowing out. Instead pieces of ice are sometimes coming out. How to troubleshoot?
I had this exact same problem with my air conditioner! What happened was, I didn't clean the air filter for a long time and hence the pilled up dust prevented the cold air form coming out, forming the ice.. Open the top of the AC and clean the air filters ASAP!!
Posted on Feb 03, 2014
  • 674 Answers
Is the fan running? If the fan is running you should check your filter. If it isn't running then you should check the capacitor for the fan and the fan motor. Also make sure the evaporator coil is clean. If all of this is good then get the refrigerant charge checked.
Posted on Jun 06, 2010
  • Brian Niten Jun 06, 2010
    It looks like what I wrote didn't help. If you could give me some feed back as to what you found it would help to solve your problem.
2008 Ford Edge ac runs only sometimes.... If I hit under the dashboard it will turn on but only blows out a little cold air on the highest setting. If I open the glove box I heat tons of air blowing. I was...
It could be the blower motor resistor or even the blower motor. If you hear the air blowing with the glove box open but, none can be felt, check the cabin air filter. This filter can become clogged with leaves and debris that enter the HVAC box. The filter is located underneath the dash near the blower motor. The reason for some air flow after you hit the dash is it must be clogged and it clears enough to allow for the small amount of air to pass.
Mar 05, 2015 | Ford Cars & Trucks
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
What is the problem now? Please can you help?
If you turn on your AC on one day and nothing happens, you may be dealing with a major component failure. Your vehicle's AC system consists of a compressor, condenser, evaporator, expansion valve, a series of tubes and several fans/blowers. If either one of these components fails to do their job, it may result an entire system failure. For example, if the evaporator blower motor burns out, you will get little to no airflow through the vents.
Most modern vehicles also have safety mechanisms that may prevent a component from engaging if the pressure is low in the system due to a refrigerant leak. Refrigerant can leak for many reasons, including undone welds, loose connections, corrosion, physical damage from road debris, etc. Look for oily stains underneath your car, as they may indicate a leak. If you suspect a refrigerant leak, take your car to General Automotive. We will test the pressure and use special dyes to pinpoint the leak.
Warm Air is Coming Out Instead of Cold As you get in your car and turn on your AC, you probably expect it to be blowing hot air for the first minute or two until the system cycles through enough to cool it. But what if the air never gets cold ? Or maybe it it gets cooler, but not cold enough ? No, your car didn't get confused and turned on heat by accident. There is likely a problem with your condenser.
A condenser's job in a vehicle is to cool the warm refrigerant that was used to make the air cold in the evaporator. A condenser has coils and a fan to push the air through the coils and thus cool the refrigerant. If the condenser coils get dirty or clogged, or if the fan fails, the refrigerant won't be cooled completely, so the air will come out warm. It's best to take your vehicle to an experienced AC Repair professional to troubleshoot this problem if you don't know your way around under the hood.
Cold Air Blows Intermittently So you went for a road trip or a long drive, and after 30 minutes of driving realized that your AC suddenly stopped working or switched to blowing warm air. The cold air returns shortly, and the cycle repeats itself for as long as you are driving. What's wrong with your car?
Intermittent cooling is often caused by the components of your vehicle's AC system freezing up. Typically an iced over evaporator is the culprit. An evaporator covered in ice can't cool the air, so you would have to wait until the ice melts, which is why the cold air eventually returns. There may be numerous issues causing the icing-from a dirty cabin air filter to a blocked evaporator drain or an overcharged system. Look for puddles of water under your car-this could be a sign of a freezing problem.
Oct 25, 2017 | 1999 GMC Safari
I have a 98 blazer that in the morning blows ice cold air. After driving for awhile it will stop blowing cold and if you turn it off wait and turn ot back on it sometimes blows cold again. ANy ideas
I would replace the low pressure AC compressor cycling switch, it may be sticking, it is a fairly common problem. The switch is located in the low side of the AC system hoses or accumulator.
Jul 22, 2011 | 1994 Chevrolet S-10 Blazer
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Voltage Stabilizer for LG 1.5 ton window type ac
You should have around 120-125 volts at the outlet. If you have less than 110 volts at that one outlet, you may need to have your house wiring checked. Go ahead and call your local power company and have the power coming into your house checked at their transformer. They should do this at no charge to you.
Aug 02, 2009 | Heating & Cooling
Honda acac sometimes blows some kind of dew air throught he vents
u most likely have some condensation building up in evap box ,,need to clean it out before it gets worse,,,if u are running it on low blower ,it is going to put out mist sometimes (if the air is really cold) because of the expansion valve pulling down the tempurature
Jul 06, 2009 | 1996 Honda Accord
AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Jul 03, 2009 | Goldstar M5200R Air Conditioner
Some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Jun 11, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Samsung AW0503B Air Conditioner Logo
122 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
