Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
I have a Yardman self propelled mower with the
I have a Yardman self propelled mower with the larger rear wheels. the pull rope broke and I am wanting to know if I can replace the rope/clutch assembly to fix this mower ir will I need to get a new mower
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 77 Answers
SOURCE: starts but when chock goes off stops running
OK take and check this. A lot of the honda engines,especially push mowers,tillers and pressure washers,they put a type of coating inside the gas tank. The bad thing about this type of coating is it has a tendency to peal and wash into the carb. I would look inside the tank to see if there is any debris. I would also clamp off the fuel line and take out the bolt that holds the fuel bowl on and catch the fuel that drains out in a clean tray. If it looks dirty,pull the carb and clean it,it should fix it.
Posted on Aug 09, 2009
  • 93 Answers
SOURCE: yardman self propelled mower model 1619295.
Go to MTD.com or any of several mower parts stores for an on-line diagram and part numbers.
Posted on Sep 17, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
  • 13 Answers
SOURCE: I have an older 21" self propelled mower with a
Need more info on what happens when you try and use the electric start and the rope start- does the engine turn over at all with either one?
Posted on Aug 15, 2010
Club cadet src 621 6.75 horsepower rear wheel drive self-propelled it has fresh gas, oil, compression and spark but will not turn over any sujestions? Thanks
how do you get spark if it will not turn over .remove spark plug and pull the rope . see what you get sometimes the fuel overfills and the cylinder will be full of gas . when and if that is case get as much out as possible by pulling rope then put plug in and try again .
May 07, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
The rear wheels on my 22" Husquvarna mower, self propelled
sounds like the reinforcement bar across the back is broke or missing
Aug 18, 2009 | Garden
Lawn boy mower bought used wouldnt start then the rope broke
there are 3 bolts that you remove and thatwill allow the coil houseing to come off pull off buy new rope and wind the rop onto the rope holder then roll the spring to it's tighest postion put pull handle on and tie know it rope burn the end of the rope with a lighter to keep it from comming apart, be sure to thread the rope threw any holes before tieing knot. then replace it back on and bolt it together. and your set.
Jun 22, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Pull start rope broke
You have to remove the whole cover. Do not break rivets. Remove the rest of old rope, then wind pulley/spring the direction it would turn if the rope was being pulled. When it's wound tight, back off to align hole in cover and pulley. Insert end of about an 8' rope from the outside the cover through the pulley and tie a single knot/loop. Then let the rope be drawn in by the pulley/spring.
Jun 20, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
517 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
