Question about Remington Electric Chain Saw
Chain fell off during use. Took cover off & book does not show how to reassemble.
    Brigadier General:
  • 4,088 Answers
First, check the chain for any bending (sideways), or broken/damaged links/teeth. If ok, clean the drive area and the oil passages in the drive end of the bar, then fit the bar and push it back toward the saw. Place the chain over the sprocket (which you checked for any damage as well), then work the chain over the bar (make sure the bottom run of chain cuts toward you). Pull the bar out as far as the chain permits, then fit the cover making sure that the adjustment tang fits into one of the large holes and run the mounting fasteners up finger tight. Turn the adjustment screw CW until the chain pulls up to the lower side of the bar, but it can still be pulled by hand. Tighten the fasteners firmly and recheck the chain. Finally, run the tip of the bar near some cardboard for several moments--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Posted on Jun 14, 2010
Chain oil is not oiling chain. Could it be clogged? First time I used machine.
Is it new (return it!)? Did you put bar and chain oil in the reservoir?
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Providing a make, model & serial numbers help us help you. Without these we can only provide a general answer. There are in excess of 5000 different chainsaws.
Nov 24, 2009 | Poulan Garden
Automatic chain oiler will not function
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 27, 2009 | Garden
Chain oiler not working
Oil System Plugged.
Lou
Oct 15, 2009 | McCulloch Garden
Chain and bar do not seem to be getting oil. Have not had to refillbar oil in a long time.
Oil System Plugged.
Lou
Oct 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My husqavara saw wont oil tthe chain .. what should i do
Oil System Plugged.
Lou
Oct 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The chain saw is not oiling the chain. NO oil is coming out. It is not reaching the bar.
Oil System Plugged.
Lou
Oct 12, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain saw does not get oiled?
Oil System Plugged.
Lou
Oct 05, 2009 | Garden
Chain oil Not getting to chain
Oil System Plugged.
Lou
Oct 04, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Automatic oiler won't oil chain.
Oil System Plugged.
Lou
Oct 03, 2009 | Garden
Oiler not working
Had you provided the model number we could have provided a more complete answer. What little oil system routing detial there is resides on the IPL. It can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 30, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Remington Electric Chain Saw  Logo
81 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
