Question about LG LSC26905TT Side by Side Refrigerator
Ice maker crushes even when it is in the cube
Ice maker crushes the ice even when it is in the cube setting . I have unplugged the fridge and it made no difference.
  • 5,081 Answers
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Posted on Jun 06, 2010
  • Bruce Freedman Apr 04, 2011
    That is not my problem. The part at the back that the solenoid controls is broken, but I can't find the description here on how to order, remove and replace. Any help would be appreciated.
My freezer compartment is cold enough to act as a fridge but not cold enough to freeze items, my ice machine has stopped working and also the buzzer to notify you that either the freezer or fridge door is open...any help on what the problem could be would be much oblige...
jb
Posted on Aug 31, 2011
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Ice dispenser only dispensed crushed ice, not cubes.
there is a metal rod that sticks out the back of the ice maker bin, it has a spring around it. it needs to fit into hole in the back of the fridge.
May 17, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Apr 17, 2009 | Frigidaire Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice maker is crushing ice when cubed ice button is on
The problem is in the selector switch itself. If it is a touch pad, you will have to reset the control board by unplugging the until for 3 min. if its a physical switch, it may be faulty and will need to be replaced.
Good luck. please rate my answer as a fixya!
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice type won't change
If this is a mechanical unit, look for a bent or broken part. Electrical...this will likely also be a bent or broken part. Unplug before servicing this unit.
Nov 17, 2007 | Samsung RS2630SH Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
834 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
